Question about YouTube Videos
1997 mustang wont start. Turns over has 35 psi fuel pressure.
Turns over. Why won't it start?
Did you check your fuel pressure it should be about 55 to 60 psi
Dec 19, 2015 | 1997 Buick Riviera
Plymouth voyager problems
check for fuel pressure with a gauge it should be around 35 lbs pressure. it may need a fuel pump assembly.
Jul 03, 2014 | 1997 Plymouth Grand Voyager
1997 chevy blazer... fuel pump turns on. have to prime to start it. when starts revs then stalls out
sounds like ur fuel pump is burned out (broken impellor) get a new one.
of course she revs and dies if u pour fuel down the carby...duh.
Nov 21, 2013 | 1997 Chevrolet Blazer
I have a 1997 Ford Escort, and it will start but immediately cut off. You can hear the fuel pump turn on when you start it. What could be the problem?
Hello awlashun,
Try spraying starting fluid into the air box if it starts it's a good possibility that the fuel pump is bad.
If you have a fuel pressure gauge check the pressure it should be 35-45 psi.
Regards,
netvan
Mar 06, 2011 | 1997 Ford Escort
Car just turns over wont start
When you turn on the key, the fuel pump runs for one second to bring the pressure in the fuel rail up to spec. If it does not do this, the car won't start. Have the fuel rail pressure tested. It should be between 35 and 40 PSI. Suspect the fuel pump relay. There could also be ignition problems, but make sure this pressure is ok first.
Apr 02, 2010 | 1995 Ford Taurus
1997 Ford windstar Low power and very poor acceleration under load. Bogs down severly under load. No codes, fuel pressure at 35 at idle and around 40 under a load.
35 is low fuel pressure, should be around 40-44 PSI and 46-50 PSI under a load, replace the fuel filter it may be clogged.
Oct 21, 2009 | 1998 Ford Windstar
Car ran fine one day, not it will crank but not
Your fuel system requires 35-45 PSI. If you don't have this pressure in the line then your fuel filter or fuel pump is at fault.
Jun 11, 2009 | 1987 Ford Mustang
Car wont start
make sure to have a fuel pressure test done to it, it must to have a least 35 psi of pressure, also see if car is equiped with map sensor if it does unplug sensor and try to start the car, if start replace map sensor
Jun 16, 2008 | 1999 Ford Escort
YouTube Videos Logo
14 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
