P4vm800 manual Cpu fan works but no picture screen and no beep.
  • 1 more comment
  • Edward Morgan
    Edward Morgan Jan 04, 2014
    Hi Surasit , I want to help you with your problem, but I need more information from you. Do you see your keyboard lights flash?
  • Surasit
    Surasit Jan 04, 2014
    Thank you. it no signal but Mb's LED lights.
  • danijel_33 Jan 24, 2014
    first removecable from power supply and U can try resset MBO with button between sata connectors and chipset plug in Electric cable in Power Supply if problem stay tray take out the memory and try to run the PC if the PC starts shrill clean the contacts on the memory with eraser pen or replacing memory.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
You may need a new video card and make sure that your ram is in all the way check all contact of the power plugs and cables as well.jim
Posted on Jan 12, 2014
  • Surasit
    Surasit Jan 16, 2014
    thanks
3 Suggested Answers
  • 43 Answers
SOURCE: NO VIDEO SIGNAL NO BEEPS ONLY CPU FAN WORKING
Please verify that you have a good processor. It seems that your processor is bad.
Posted on Oct 31, 2009
bronk50
  • 27725 Answers
SOURCE: motherboard asrock P4VM800, we have
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on May 05, 2011
Sys fan nor cpu fan working and black screen
Try a known , good working PS. If that does not do it, you have serious mo bo issues.
Mar 27, 2017 | ASUS PTGD1-LA Motherboard
CPU fan & PSU fan working but No display coming to the screen
There should be some sort of beeps then. No beeps is an indication the CPU or RAM is not seated properly. You need to refer to board manual if there are beeps.
There is also the matter of... Never mind I just noticed the CPU is an 8 core CPU, but the board supports quad core.
Board specs
http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
CPU Specs
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
Double check my findings and go from there. Good Luck
Dec 11, 2012 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
Asrock P4vM800 no audio or video
Hello you can download a manual here:
http://www.asrock.com/mb/VIA/P4VM800/?cat=Manual
You need adobe reader to read the content.
My guess is the power supply is failing try to change
it with one you know works.
Look also for bad capasitors on the mainboard:
They should not look like this.
If this is the problem the mainboard must be replaced.
It will exeed the price for a new mainboard to let them be changed.
Good luck
Nov 29, 2012 | Asrock P4VM800 Motherboard
Motherboard asrock P4VM800, we have checked and replaced everything with known good Ram, PSU, heatsink. We have confirmed that everything is connected correctly. when you power on the unit the cpu fan...
hard drive
hope this helps
May 05, 2011 | Asrock P4VM800 Motherboard
I want to upgrade my cpu for this mother board from 1.8 ghz to 2.8 ghz. What cpu should I go with. Am I going to run into problems with the bios or anything else. Also need to know if I can upgrade...
Here is a link for your mobo
http://www.asrock.com/MB/overview.asp?Model=P4VM800
looks like you can use any intel processor as long as its a socket478 by intel
Check out nvidia agp cards at www.nvidia.com You can get a 512mb card agp.
The bios is plug and play which should not be a problem.
You may need to upgrade the memory also.
Mar 22, 2011 | Asrock P4VM800 Motherboard
P4vm800 not working how to solve this probelom
Good day sir, hi, lets make sure first that your motherboard is good, so we need to test it, just prepare the folowing items.
  1. A good working power supply, to test: place a jumper wire across the green wire and any black(or sometimes the red with work) wire on the 20/24 pin power connector. Plug it and see if the exhaust fan run.
  2. A good set of Ram, just make sure its good. if not or in doubt buy new one (only one module) if you want. (you can keep the doubtful ones and test it later)
  3. A keyboard.
  4. If your motherboard has no VGA onboard, A good VGA card.
  5. A thumb speaker, or you can use your PC case speaker.
Okay lets assemble, on a table:
  1. Place your motherboard, (make sure no metals underneath) connect the Power Supply 20(or 24) pin to your motherboard and the 4 pin 12v connector. (if your motherboard has one).
  2. Connect the pc thumb speaker or your case speaker.
  3. connect the keyboard.
  4. connect the RAM, make sure it clicks as you install it.
  5. Optional VGA card. Onboard vga will do. Connect a monitor. plug in the monitor.
Okay, plug in your power supply, (exhaust fan is off at the moment) locate the power button pins, short them with a screwdriver. (fan is now on)
Now check your Keyboard. you will see two sets of lights, first set is Num Lock + Scroll Lock + Caps Lock, then a few seconds the second set: Num Lock only. at this point your motherboard is good.
Also check out the PC speaker beeps.
  • 1 beep mean good.
  • 1 long and 3 short beeps VGA is bad. (it may help if the VGA is snug and fit on the slot). If on board VGA, use a new AGP/PCIe card.
  • Continous long beeps. cannot detect memory
  • Continous short beeps, motherboard. (or memory sometimes).
  • No beep, fan is on.at this point do everything again. (do it several times until the board responds)
Hope this helps you. feel free to ask again.
Oct 14, 2009 | Asrock P4VM800 Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
No startup of the mother board
Sounds like a videocard problem. REseat your videocard and memory sticks making sure they are all well setaed...
Aug 29, 2008 | Asrock P4VM800 Motherboard
Asrock motherboard
Look HERE for a list of bios beep codes
May 18, 2008 | Asrock P4VM800 Motherboard
Error signal ASRock P4VM800
When you open to you're bios menu, either at the top or at the bottom of the screen will be a name of you'e bios. In you're case the name is at the bottom of your bios menu. (American Megatrends Inc.). Or for short AMI You could search google for, AMI bios beep codes.
And you can click on this link, which shows what AMI say's about 3 beeps.
http://www.bioscentral.com/beepcodes/amibeep.htm
You need to test you're memory. (Only if cleaning the memory has did not change the beep error beeps).
First remove you're memory & blow out the DIMM slots with canned air. Clean the copper on the memory with house hold alcohol on a lightly dampend cotton swab. (Let it dry), (Do not touch the copper with you're fingers. Re-install you're memory.
If you have more than one DIMM. Remove the bank farthest from the CPU & boot the PC. Did you hear the 3 beeps? Remove the the next bank & re-install the one you removed first in to the slot closest to the CPU. Boot the PC, again did you hear the 3 beeps?
If I can be of more service, just post back & let me know how thing go.
Good Luck!
Mike
Apr 27, 2008 | Asrock P4VM800 Socket478/SAT/A&V&L/Modem...
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
