Question about Precor EFX 5.21 Elliptical Fitness Crosstrainer
Replace drive belt for precor elliptical efx5.21i
Replace drive belt
5 Suggested Answers
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
SOURCE: the resistance on my Precor elliptical 5.17 will
There is a small motor under the shroud that operates the resistance motor. It is about the size of a roll of half dollars. Have someone use a meter and check that you are getting power to this. When you turn on the machine the motor should move the resistance forward then back. You can hear this everytime you turn it on.
Posted on Mar 11, 2010
bwinton
  • 83 Answers
SOURCE: I own a Precor EFX 5.33 the drive belt snapped so
You use the two bolts that hold the step up pulley in place. The step up pulley is the pulley assembly that is closes to the back of the unit. The step up pulley slides into two grooves in the frame, then there is a bolt on each side that run down the groove into the step up pulley. These bolts are the bolts that adjust the tension for the skinny belt. You may need to loosen the other belt first then tighten the skinny then retighten the belt you replaced.
Posted on Mar 19, 2010
dcramer531
  • 1654 Answers
SOURCE: How do I replace the
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots on whom the sell parts and support to.
There is a place on line to get some of these, it is. www.treadmilldoctor.com/Products-Services2/precor-treadmill-belt.
The manual can be found at. fitness.manualsonline.com/ex/thread/view/idThread/2141832
This place has manuals and user manulas along with support and some partswww.shopwiki.com/Precor+EFX+5.171 I believe this unit has a 10 yr warranty with it and the part in question may be covered by them. There is also a 1 year part warrant for other parts, I just don't know what parts they are covering for the 10 yr.
Posted on Dec 26, 2010
Why is the Precor AMT 100i Adaptive Motion Trainer Elliptical primary belt making noise and should I adjust it?
SOmetimes belts make noise when they are worn out and need to be replaced - belts like that are considered 'wear' items, like tires on a car - they have a very limited lifespan compared to the other parts.
Jun 18, 2014 | Precor AMT 100i Adaptive Motion Trainer...
Why is my Precor Efx 546i elliptical showing an error message?
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29
Feb 11, 2014 | Exercise & Fitness
Precor efx 5.33 belt replacement
This link will take you to the replacement belt. If you use your serial number, you will be able to access a service manual on our Website to assist with the belt change. Drive Belt Poly EFX PPP000000010217131 SPORTSMITH net
Jul 01, 2012 | Precor EFX 546i Elliptical Version 4
My drive belt for my Precor EFX 5.33 broke. I have a replacement belt and would like detailed instructions on how to replace it.
Use this link and have your serial number ready. On the left of the screen, you will have the option to click on your serial number range. You should see a tab in the middle of the screen that shows manuals. Click on the service manual and you will have the information you're looking for.
Repair Parts for Precor 5 33 Ellipticals Consumer SPORTSMITH net
Feb 27, 2011 | Precor EFX 546i Elliptical Version 4
I have a Precor EFX 546. How do I replace the drive belt?
Using your model and serial number, use this link to view a service manual with procedure instructions. http://www.sportsmith.net/
Sep 19, 2010 | Precor EFX 546i Elliptical Version 4
I own a Precor EFX 5.33 the drive belt snapped so i bought a replacement belt and i've installed it and i can't align the other belt. How do i get the skinny belt to fit snug?
Mar 19, 2010 | Precor EFX 546i Elliptical Version 4
Belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
Feb 26, 2010 | Precor EFX 546i Elliptical Version 4
There is a squeeking sound when it's being used.
Sorry to say its time to replace the belts You may purchase them directly from Precor @ 1-800-347-4404 or
http://www.gympart.com or http://www.sportsmith.net
Have your serial number
Dec 15, 2009 | Precor EFX 546i Elliptical Version 4
Precor EFX 5.21 Elliptical Fitness Crosstrainer Logo
76 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
