Question about Golds Gym StrideTrainer 380 Elliptical
Monitor won't turn off and keeps beeping
What is causing my monitor to beep on its own (every 30 seconds). The monitor will not turn off on its own. I have to remove the batteries.
  • Golds Gym Master
  • 6,694 Answers
The control panel is faulty. You have to change the control panel
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Jun 19, 2016
System keeps rebooting
Check the plug that goes into the monitor for secure connections. Check Samsung for any firmware updates. Pay attention to how many beeps before shutdown, this could be a code to the problem. Samsung does have a help line to call look in manual. Not really familiar with security systems. If a computer was acting this way I would say it is possible the hard drive is bad. http://www.samsungsv.com/Support/ContactUs
Mar 17, 2014 | Samsung 8ch Security System Sme-2220...
Nuvico nvjv 4000 beeps and shuts off
sometimes these will go into an automatic sleep mode and will restart once you power it down and restart..
Jan 19, 2014 | Nuvico NVJV-4000N Video Recorder
Won t stop beeping
if it's just continuously beeping, then you may have a shorted control board. This isn't an error code, so if it keeps beeping, you may need to replace the control board itself.
Dec 18, 2013 | GE Dishwashers
Power flashes on for a second and then turns off completely
The most likely problem is that the power supply has failed.
Jul 19, 2013 | Shuttle XPC SD32G2 Barebone
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
I turn on my computer and i cant see any thing on the monitor my monitor says no signal
Thanks for the response, I opened it and the processor is burnt, one corner of it. Was a lot dust in there maybe that caused it? Anyway I found a new one on EBay for 30 bucks, the board looks fine so that should work huh?
Sep 21, 2010 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
My acer 19" monitor has no signal what should i do?
  1. check whether the signal cable properly connected to the vga port or not ?
2.listen the single beep from PC
3.try monitor on another PC . if persists , then the fault lies in the monitor . if not then the fault is in the CPU
thank you.
4.if no beep from CPU then disconnect RAM . listen contineus beep . if heard , then the RAM is faulty , replace it .
Jul 23, 2010 | Acer AL1916W 19" LCD Monitor
My monitor won't show the display even though it is turned on
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card. When the PC turn on there is any beep. If no beep then your RAM is alright. Problem in VGA Card.
Mar 21, 2010 | Sony SDM-HS75P/S 17" LCD Monitor
My Samsung Syncmaster 240T stopped working today. I tried turning it on, and it starter emitting a constant short beep once every 2 seconds or so, along with the green Video light blinking every time it...
Your Back light inverter power board has died. The beeping and blinking are caused by the power board repeatedly trying to start up and failing. This is a common failure point of LCD monitors2.gif after a few years of use. The heat build up in the monitor case causes parts called capacitors to blow leading to the power supply short. If you can solder you should be able to do the repair. Go to our web site at:
www.ccl-la.com/badcaps.htm We have pictures of what to look for. Now take the back off of your monitor and replace all of the caps that look like the pictures and you should be back going again. Be sure to use high temp parts, they will be marked 105c. The values you will need to get will be marked on the sides of the bad ones such as 220uf, 470uf or 1000uf. When you insert the new ones be sure to put the polarity stripe going the same direction as the old one comes out. If you have any questions just let me know. If you don't want to do the repair yourself we do offer a repair service for $30 + return shipping2.gif.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 03, 2009 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Machine beeps, no movement, monitor missing, tried turn on off.
Remove the batteries and unplug for 30 seconds plug in and test. Unpluging and removing the batteries causes it to reset to defalt settings.
DickyO
May 29, 2009 | IBM Wheelwriter 30 Typewriter
Golds Gym StrideTrainer 380 Elliptical Logo
193 people viewed this question
Top Golds Gym Exercise & Fitness Experts
Steven's...
Steven's...
Sock Puppet
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
