Question about Garden
Idling Issue I have an idling issue with my sportsman. It runs fine, however when i come to a stop it dies. It will fire right back up if I give it a little gas. I adjusted the idle and that did not solve the problem. Any suggestions? Thanks.
    Master:
  • 485 Answers
Check the EGR valve.
Posted on Jan 16, 2014
4 Suggested Answers
SOURCE: engine on my 04 sportsman 400 wo'nt idle unlesss
there is an electronic position sensor in the throttle housing and if the throttle cable sticks even a little the sensor interrupts the flow of electricity and disables the engine to prevent loss of control so chase down your cable and lubricate it and make sure you have full range of movement
Posted on Apr 03, 2009
  • 38 Answers
SOURCE: I have a 2006 Polaris 800 sportsman and it won't stay idleing
adjust the idle screw
Posted on Oct 01, 2009
wadembly
  • 513 Answers
SOURCE: Polaris 500 idles fine but when i give it any gas
the idle air mixture might be off or sometimes a bad spark plug can cause it
Posted on Nov 13, 2009
I have a 2006 Polaris Sportsman 800 twin efi it idles just fine but when I give it gas it dies?
Hi ! for an informantion,please visit the website below. If you need more information about a specific electrical issue you can reach me at motor@motorpartstore.com Motor Part Store Motor Parts Wholesale
Apr 28, 2016 | ATVs
2007 500efi won't idle restarts and revs up but back fires and dies
check for a vacuum leak first... then suspect a idle control solenoid issue
Oct 11, 2014 | Polaris 2007 Sportsman 500 EFI
I have a 2004 polaris sportsman 500 when it gets hot it cuts off and back fires
sounds like the coil is weak or the electronic spark box is goin fuel filter been changed ?right gap on the Plugs? need more imfo on it to do more thks
Jul 29, 2014 | Polaris 2004 Sportsman 500 H.O
I have a 1993 ford festiva its a good little car it runs good when the engine is cold but when it warms up it sputters and dies on me when it dies it fires right back up like nothing ever happened It...
If it has an automatic choke, this will keep it revving more when the engine is cold and less when hot. Maybe adjust the idle setting screw on the carburettor so it revs slightly more. Try that before it is running hot. Only increase the revving gradually to the stage where stalling would be avoided when hot. Gradually so that there is not too much revving when cold. Adjusting and testing over a few runs could be a good strategy
Feb 28, 2014 | Ford Festiva Cars & Trucks
Idling Issue with Sportsman 600
Jan 03, 2014 | Polaris ATV
03 winstar won't start, shakes ,back fires, fires 3times dies.
More than one issue, maybe? Also consider other experts' solutions.
First, it sounds like the EGR valve is sticking open. The exhaust valve is supposed to be closed when idling, otherwise open. It recirculates exhaust back into the manifold; can't idle car very well when the valve is open, but should not cause backfire.
Backfire, is generally an ignition timing issue: the ECM (electronic control module) is responsible for that. Check it / replace it.
Worst case: small break in one of the head gaskets (not likely, but symptom is the same).
Vacuum leak, too???
Hope this gets you pointed in the right direction!
Sep 21, 2009 | 2003 Ford Windstar
My 1999 Alero has been stopping, especially while idling at a stop light. As long as the car is in perpetual motion, it runs relatively fine. When it stops, the engine oil light and the batter light come...
You don't have right AIR: GAS ratio of 14.6:1 at idle. If you don't have idle adjustment, you need to have throttle valve clean.
If it doesn't work, then your Fuel Distributor is drifting out of calibration.
Don't worry about check engine light comes on when the engine dies. It is designed that way.
Aug 11, 2009 | 1999 Oldsmobile Alero
1979 320i - car dies when it "warms up"
Check the tempurature when it's die, maybe over heated, check the cooling fan, water pumpand and thermostat, BMW is alumimum engine, becareful!!!
Jul 12, 2008 | 2001 BMW 325
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
