Question about Ricoh Aficio 2045 2035 Nvram B022-9590 - Zero Counter
SC 990 IN RICOH 2045
Cogz
  • 1326 Answers
SOURCE: ricoh 2045 sc 990 when i fix printer its appear
Did the donner copier have a finisher on it? The code means a miss comunication with the finisher. There is a HD that is used with a finisher. The meter count can not be changed that I know of......The reason it shows 000000 is that the battery was disconnected from the eprom.
Posted on Mar 15, 2009
SOURCE: dear sir i have problem in ricoh 2045 its give the sc 990
if changing drum... The problem persists.
Try press the .(point) and # key Both simultaneously more of 10 sec. This reset the condition, the copier shut off and on automatically and print a error report.
Also the hard disk can cause this problem... change.
Posted on Sep 14, 2009
  • 21 Answers
SOURCE: Sc 990 ERROR PROBLEM ON
replace drum, drum cleaning blade,charge roller. this will sort Sc 990
Posted on Oct 21, 2010
santosj27
  • 263 Answers
SOURCE: IN RICOH AF 2045 SC
This error code could be related to a Physical problem (machine) or Network Problem.
Physical problem:
Try to clean the ID sensor.
Probably you will also need to clean or replace the Drum Unit.
Network problem:
Upgrade your firmware.
(If you do not have technical skills a advise you to call your provider)
See you!
Posted on Jun 06, 2011
SOURCE: i have problem in Ricoh AF 2045 SC 990 pl z help
this is software performance error.but this in most cases will appear on life over of either drum or developer.
Posted on Aug 10, 2011
I have an sc 326 error code in my ricoh aficio 2045 copier
If you wish to get some details; check the site linked here. Pull up older posts....
Jun 19, 2016 | Ricoh Aficio 2045e 2035e Copier...
Hai ....am vivek .please help me dears...i have RICOH Aficio 2045 ...it will appears sc 990. What's the solution for this error?? Plz help me ...
SC 990 is software performance error. This means The software attempted to perform an unexpected operation.
Possible causes:
1. Software defective
2.Internal parameter incorrect
3.Insufficient working memory
4.When SC occurs, the file name, address and data will be stored in NV RAM this information can be checked by using SP 7403. Note the above data and situation in which this SC occurs. Then report the data and conditions to your technical control center.
Apr 23, 2013 | Office Equipment & Supplies
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
I have problem in Ricoh AF 2045 SC 990 pl z help me out from it
Jul 26, 2011 | Ricoh Aficio 2035 Copier
IN RICOH AF 2045 SC 990
Physical problem:
Network problem:
See you!
Jun 06, 2011 | Ricoh Aficio 2035 Copier
Sc 990 ERROR PROBLEM ON RICOH 2045/2035. how can i solve this problem..
Sep 14, 2010 | Ricoh Office Equipment & Supplies
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Ricoh 2045 sc 990 when i fix printer its appear
Mar 14, 2009 | Ricoh Aficio 450 Copier
Sc990on af 2045
SC 990 is a software error. It usually can be cleared by turning the machine off and back on. It occurs when the internal program gets locked up. Sometimes it requires a firmware reload, other times it maybe an indication that your hard drive is on its way out. The best thing I can say, is lets hope it just happened, and will not again!
Mar 19, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 2045 2035 Nvram B022-9590 - Zero Counter Logo
35 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
