Question about Refrigerators
Ge integrated ice system
Integrated Ice System has black particles on the ice when I use the button on the door. But if I open the door, pull the IIS (integrated ice system) out the ice has much less black particles on it. [a friend of mine made the assumption that this could be the minerals or something in the filtration system getting out, but neither of us are experts on the situation]
freetek
  • 5568 Answers
SOURCE: I have a GE Monogram
Icemakers=troublemakers. About 9 of 10 failures occur there first.
You didn't state whether the water supply is still present or the motor that drives the eject mechanism is still trying to turn.
Check your water supply at the rear of the unit to see if it is getting any, and change any filter through which the supply water flows.
Posted on Jun 24, 2008
woobie dog
  • 1273 Answers
SOURCE: our Bosch icemaker was replaced along with the
Hello. Woobie here.
A new filter contains activated carbon, and, if your particles are dark, this is probably the problem. A new cartridge will have some loose material in it, and this flushes on through to the dispenser(s). The fix can be effected two ways: If the filter is new, remove it and dunk it in a pot of water several times, draining it between dunkings. This decants the loose materials and will alleviate the particulates. If the filter has been in a while, tha particulates will have mostly moved on through the system (and into your system!). Activated carbon is not harmful. If you fall somewhere in between the lengths described, decanting the filter may still provide some relief, again, depending on how long it has been in service. As a general rule, always dunk and decant a new filter prior to installation to keep the particulates to a minimum.
Best regards,
--W/D--
Posted on Nov 09, 2009
  • 3230 Answers
SOURCE: My GE integrated ice system
Well Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat. Please post comments for more help or information.........
Good Luck!!
Thanks
Posted on Dec 28, 2009
tunde007
  • 2382 Answers
SOURCE: I have a GE Arctica
Hi, it sounds like you have a bad auger motor which rotates to dispense ice. You need to replace the auger motor..
Posted on Aug 24, 2010
bobicehouse
  • 1524 Answers
SOURCE: Whirlpool ice maker will not
The temperature lower then 19*F ?
Posted on Nov 02, 2010
Why is light blinking on ge adora integrated ice system
It is time to change the water filter. See page 6 of your owners manual. If you don't have your copy of the manual, click here.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60412-1.pdf
Aug 16, 2014 | GE Adora (DSF25KGTBG) Side by Side...
Ge model pfss6pkxass integrated ice maker not making enough ice
it could be to much force maybe back off the supply tap to the water side of it and see how it goes
Apr 08, 2014 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
My GE integrated ice system stopped making ice but the water still works?
Good Luck!!
Thanks
Dec 28, 2009 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Particles in ice cubes
Most new water/ice systems have break-in procedures in the manual, including flush a couple gallons of water through the water dispenser and disposing the first 24hrs of ice.
Are the particles present in the filtered water before adding ice? If so, you can probably assume the contamination is from the water tank so you should flush several gallons of water through the system to get rid. If the particles are present after adding ice, try pulling out the ice bin and dumping the ice.
Dec 30, 2008 | Whirlpool ED2FHEXN Side by Side...
I have a GE Monogram fridge with the integrated ice maker system. It quit making ice about a week ago. I have cleaned it out, but it will no longer make ice. Is there anything I need to try before I give...
Jun 24, 2008 | GE Refrigerators
Ice door opener
GE side x side GSS22SGMC stainless steelJust fixed my own problem of jammed ice door. 1. pull the light switch plate off (just under the front bottom edge, push through the holes, pull) 2. unscrew the dispenser assembly, 4 screws, pull the unit out  3. WR62X10020 SOLENOID is in the upper right, unplug the black wires from the board. 4. unscrew the right screw from the door-stop assembly (above the ice door)- pull the plastic out of the solenoid piston 4. unscrew solenoid, 3 screws, from back 5. pull the piston, scrape-sand-file off all rust, then lube with oil 6. scrape off rust from inside,  solenoid with shoving steel wool-file-degreaser to get off rust, then lube 7. reassemble, WORKS!! 8. save 35.00 for new solenoid 9. save repair cost of whole new door (happened!) good luck
Feb 20, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
11 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
