Question about Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Dryer runs for a few minutes and shuts off
Mod#medc200xw1 dryer will start up after it cools down vent hose has been cleaned out and problem persists
jsrock516
  • 5911 Answers
SOURCE: After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Posted on Apr 29, 2007
  • 1003 Answers
SOURCE: Dryer beeps, shuts down
replace power control board
Posted on Jan 21, 2008
  • 59 Answers
SOURCE: Dryer shuts off after a
Unfortunately you have already checked the obvious problem. Dryers are fitted with a safety switch to cut out if the heating elements get over hot. The usual reason for over heating as your aware is that the air flow over the heating element becomes restricted, usually due to something (Lint) blocking the venting pipe.
If you really have cleaned the pipe out - i.e. pulled the machine out far enough to straighten the vent pipe and see that its clear and vacuumed as var as you can see, also cleaned the intake filter where the air is drawn in and there are no obvious obstructions there, then there are two possibilities I can think of.
The first is not good news, i.e. a stray sock or other garment has managed to escape the drum of the dryer and has become lodged in the machine possibly close to the exhaust vent exit causing an obstruction prior to the pipe that you can see at the back of the machine. Thats not good news obviously because the machine has to come apart to look inside the drum and check or clean anything out.
The 2nd I am affraid is also not good news and that would be that the sensor to detect the temperature in the dryer is faulty and is tripping the system at too low a temperature, but from your comment about it getting very hot I would assume that this is not really the case.
Regards
Posted on Aug 11, 2008
dragonsthatk
  • 547 Answers
SOURCE: dryer overheats and shuts off
how long is your vent hose and how long when heated it may be kinking when heated
Posted on Feb 26, 2009
rickead1
  • 1998 Answers
SOURCE: the dryer turns on, then drys for a few minutes,then shuts down
this is either a fuse ,relay or heater problem your best to call for a technician unless you can measure continuity between each of these with the power off .90 % of the time this is due to a build up of lint inside the dryer
Posted on Apr 28, 2010
My kenmore dryer runs 10 minutes and shuts off and when you try to restart it it just clicks
Could be overheating and has shut down to cool off. Check lint filter and vents for unclogged conditions
Sep 13, 2017 | Kenmore Dryers
Dryer LG 1100 shuts off after a few minutes. If you set it for 54 minutes, you check if after 5 minutes it reads 14 minthen in 5 minutes it starts cooling down. The clothes are still wet.
Clean your lint filter, and clean the entire line vent from the dryer to the outside export port, also look inside the dryer vent hook up for obstructions and remove any lint. Keeping these parts lint free will save you energy and also drying time and maintenance repairs. My dryer is 18 years old.
Sep 29, 2015 | LG Dryers
Dryer runs for three or four minutes then shuts of and willnot start for 10 minutes or longer'
Could be motor overheating and shutting off. Need to check if drum turns freely. If it does check vent hose making sure it isn't plugged causing dryer to overheat. If motor is bad it will get worse and just not start
Sep 24, 2014 | Avanti D110 Electric Portable Dryer
Always on high heat and shuts off after 20 minutes
Check the complete venting system inside the dryer and to the vent outside. Be sure and check for lint & god knows what around the blower wheel. Get everything 100% clean. Insert a thermometer into the vent coming out of the dryer with the vent hose off. Start the dryer on high heat & see if it will go to not over 180% and start going lower like 130% or so if it drops back it's ok . If it don't stop & go down cycle thermostat is most likely bad. The reason it won't start for an hour may be the motor gets too hot. You could put an ohm meter across the connection on the cycle therm and heat it with a small torch or something & see if it will show open after heating. Just a guess lots of things cause these problems. Clean that motor too. Lint may cause it too run hot.
Mar 28, 2014 | Whirlpool Dryers
My duet whirlpool dryer runs for about 10 to 15 minutes then it shuts down
Unhook the exhaust hose, run the dryer and see if it shuts off. If it does not turn off the hose is blocked and will need to be cleaned all the way to the outside vent.
If it still shuts down it could be blocked inside the dryer or there is a bad temp sensor.
Apr 07, 2013 | Dryers
Gas lights up for about 5 minutes and then burns out. Try to turn on dryer again, but flame won't light. I let dryer sit for aout 30 minutes and turn on again - flame starts up, but will only last...
If the flame is shutting of before it reaches the operating temperatures the likely failure is a restricted venting system. There is a high limit thermostat that will cause the flame to shut off if there is a lack of airflow due to a restriction in the vent system. Remove the lint filter screen and clean in with soap and water. The filter may appear clean but it could have a clear film of fabric softener residue covering it causing a restriction in the air flow too. After cleaning the filter reinstall it before running the next test.
For testing purposes only, disconnect the dryer vent hose from the back of the dryer and put a normal load of clothes in the dryer and start the dryer. If the clothes dry in the normal amount of time that would confirm a restriction in the vent hose or the venting system. NOTE: Do not leave the vent hose disconnected after running the test. Reconnect the vent hose.
You will likely find the clothes drying in the normal amount of time indicating a restriction in the venting.
Aug 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
I have whirlpool dryer that the heat seems to kick on and off it is gas dryer
If heats for a few minutes then cuts off (heat) , then the 2 coils on the burner valve are probably bad . OR check the vent hose to the outside for good air flow . Sometimes , a dryer is pushed too far back , and it kinks the vent hose . If coils are bad , when dryer cools down , then restarting , cool coils will heat again for a few minutes , then stop heating till they cool off again .
Aug 01, 2009 | Dryers
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Electric dryer shutting off
most likely cause is the air duct is blocked with lint, some always gets past the screen and builts up in the exhaoust line. not enough air flow, the air gets hotter than normal and trips the over temperature cutout.
for most dryers
clear the fan, and exhaust ducting all the way to the wall, and the outside vent hood, of lint
Sep 22, 2008 | Whirlpool LER4634J Electric Dryer
My Kenmore Mod 110.68722700 clothes dryer stops drying the clothes if run too long. The lights are on but it appears to power off. Any help please?
Let it cool down completely. Disconnect the vent from the back and turn on the dryer. See if there is proper air flow. Try running a load with the vent hose off. If it works now the vent hose is clogged.
May 24, 2008 | Kenmore Dryers
Open Questions:
See all Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Questions
Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
