Question about Olympus X940 Digital Camera
X-940 CHARGING INDICATOR FLUCUATING
Charging indicator FLUCUATING
    Top Expert:
  • Olympus Master
  • 6,702 Answers
Please don't shoot the messenger, but I think you battery has died.
You could try to clean the contacts with a dry cloth and put the battery on and of the charger several times, to reset the charger, but if it stays that way (fluctuating light) try another battery.
Posted on Jan 05, 2014
Volvo 940 does not starts. Starter works and turns, battery has charge. Changed a fuel pump, it helped for couple weeks. Then same thing happened. Cleaned fuel relay. It also helped for couple days but...
check your pump if you replaced the pre pump in your fuel tank you must check the seal .remove the plastic ring check the base at the entry to your pump is flat .it may be leaking air due to your seal not seated in correctly.
Nov 27, 2012 | 1994 Volvo 940
Fuel indications flucuate dramatically from empty to 380 miles remaining
Hello.
This is usually dew to a broken sensor in the fuel tank or a electrical grounding issue between the tank and body.
It could as well be a gauge problem.
I hope this helps.
Dec 29, 2010 | 1999 Cadillac DeVille
Our pc 940 does solid black copy
There is an open circuit on one of the charging components in the printer cartridge, the Canon E40. Replacing the cartridge should solve the issue. Be sure to use a high quality remanufactured cartridge or an original to try to avoid such issues.
Jan 18, 2010 | Canon PC-940 Black and White Copier
Need to change osf indicator/sidelight on 1994 940 wentworth. cant see how old unit dismounts
Typically on all european fender lights you push them either towards the front or the rear of the car and that releases them. you'll simply use a fingernail to pull out on the side you push from.
Mar 26, 2009 | 1994 Volvo 940
Alternator not accepting charge
ok, this used alternator has bad diodes and will need them replaced. sometimes, certain technicians wont rebuild correctly. they just look over this vital part. i would return this alt.
Mar 03, 2009 | 1994 Volvo 940
My volvo 940 1993 keeps flashing the emission light when I restart warm car after a short trip - slow to start, need to give it some gas & rev
Sounds like you need an O2 sensor. You need to have it scanned, places like AutoZone will do this free of charge.
Feb 03, 2009 | 1994 Volvo 940
1993, 940 volvo will not start.
my 94/ 940 had the same problem turned out to be worn out crank-shaft sensor.. generic cost$115 for part .Canadian tire charged me $400 for job.would have been much cheaper had i checked forums first good luck
Dec 30, 2008 | Kalinka MB-3 Kronos Night Vision...
Volvo 940 headlights
dim lights are generally bad ground / rusty -loose ground points or wires
Jul 18, 2017 | 1994 Volvo 940
Failing smog computor says cataletyc not ready it has a knew converter
Check the oil level, to much can ruin catalytic converter. Check O2 sensors with scanner, make sure they are work accurately. Check air box while car running, apply aceteline gas with no flame, recheck scanner for O2 sensors flucuatation. Compare all sensors for flucuation of 1mv to 9mv. If sensors flucuate they are good, if no flucuation sensors need to be changed. recommend to change cat with bad sensors. Before changing cat check for bad pressure.
Sep 03, 2008 | 2002 Pontiac Grand Prix
Olympus X940 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
