Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Flickering colors, then back to black upon start up.
I have an RCA Scenuim 51" DLP. Seeing that I'm stuck with this EXPENSIVE and unreliable tv, I'm afraid that I have to repair it once again.
The only problem now however, is that my warante has expired, and I have to attempt fixing it myself. I'd really appreciate any advice to my problem.
If the tv is turned off for a while, and then is turned on, the video comes on, but the colors flicker on and off randomly, and very fast. During this flickering, the display goes black, and after a few minutes, the color flickering resumes. The power light button flickers when the tv goes black, but the tv does not turn off. The flickering display varies from 10 seconds to 30 seconds, then the black screen comes. If I let the tv do its thing (flicker to black, flicker to black) then about 30 minutes (or more) the tv finally works fine. As long as it's on (after that point), the flickering problem is gone.
My wife wants us to leave the tv on 24 hours a day to avoid this problem, but she's out of her mind.
I hope someone will be able to provide some advice.
Thanks in advance,
Tom
  • 208 Answers
SOURCE: RCA hd50lpw42yx2 not working
There are 4 1000 mf. 35 V caps. on the AC IN pwb. (power supply) that are chronic fail items. After back is off, slide the chasis on the left side back toward you. Slide about 1/2 inch and it will lift out of track and then the chasis will be more accessible. The said caps are the tallest on the bd. and 2 are located side by side on the bottom front of the chassis. The other two are side by side about an 1 1/2 above the other 2. Most likely the top of the caps are pooched out. Replace all 4 whether they look bad or not. Problem solved
Posted on Feb 10, 2008
Luvlee
  • 59 Answers
SOURCE: Really green picture with flashes
Hi...the flickering and the green is the colorwheel going bad. Very common for this model and an easy fix too.
Posted on Mar 28, 2008
SOURCE: RCA TV flickering problem
Help! I have an RCA 40 inch HDTV (Model# D40W20). I've had it since 2005. Recently, the picture will flicker when I turn it on, but will stop flickering after a few minutes. My brother has the 52 inch model and his tv did the same thing before it broke down completely. Does anyone know what the problem could be?
Posted on Jul 24, 2008
SOURCE: RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Posted on Apr 21, 2009
TheRavenator
  • 4 Answers
SOURCE: used to flicker, now dead
You possibly need to replace either the Main board, or the power board, they both can be purchased online, and you can either install yourself or go to a site like Onforce.com and accept bids.
Posted on Sep 02, 2009
RCA scenium l37wd250 stuck on antenna d channels and can't get to cable. In settings, the signal type is on cable
I have an RCA Scenuim too. Try unplugging the TV and disconnecting everything from the TV and then hooking everything back up again.
Aug 03, 2014 | Televison & Video
Hi, my 52" RCA DLP television would not turn off, instead stuck on the first cool down blue screen, and the screen started blinking blue at first and then other colors. Power light blinked 5 times. Had...
I wish I am not retired now I would still have access to RCA or figured it out my slelf.
Unless you are worried about saving electricity Let the thing stay on It will still last for years and cost less then reapair ..Don
Nov 30, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
Black and wight picture
The tv have a colors wheel.The tv make humming,buzzing motor loud noises or flickering black and white pictures.The colors wheel is dead,require changing,bcause of the colors wheel axsis rubbing on it sides or worn out,than have black & white pictures.Hire a tv tech, to do the job.Because changing the colors wheel is not easy.Require take out many machanicals parts,before even can change the colors wheel it self.
Sep 01, 2010 | Samsung DLP HL-P5663W 56" TV
Hd dlp rca scenuim
the 5 blink error is caused by faulty capacitors on the power board. There is a kit called the ATC336 power supply repair kit which contains the replacement capacitors and instructions that will usually repair that. You can get the repair kit at the following link.
http://servicemanuals.vstore.ca/
Sep 27, 2008 | RCA HD50LPW175 50" HDTV
Whining noise problem and color flickering
Its the color wheel you can get a replacement color wheel for your model and it comes with free instructions on how to index it proprly plus free tech support with on line messageing. heres the link.
Jun 18, 2008 | RCA HD50LPW165 50" Rear Projection HDTV
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
No picture whirring noise shuts off and on
DLP(digital light processor) does not have a color wheel
Oct 05, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
573 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
