Question about Audiovox Bosch 718 World Cellular Phone
Bosch nexxt 500, with dryer inservice drum or fan is making noise and has vibration. checked exhaust line from dryer to outside and line is clean always use lint filter and clean after each use.
  • 23 Answers
Does the drum turn smoothly and evenly? If not, the whole drum could have come off of its track.
Posted on Aug 15, 2009
How do I remove lint that gets past filter
There are brushes that run through the exhaust like a chimney sweep,
You can also do that by hand. What ever you do, there will be a lot of loose stuff left in the pipe; so don't clean the outside vent until last.
Oct 13, 2014 | Bosch Nexxt 500 Dryer
My Bosch Nexxt 500 dryer keeps tripping the hi-limit cut out.
Try checking your exhaust vent pipe for excessive bends and kinks, make sure there is good strong airflow coming out the exhaust where it exits the building.
Dec 12, 2013 | Bosch Nexxt 500 Dryer
My Bosch Nexxt 500 dryer is TOO HOT.
You need to take care of this right away. Too many houses catch fire from lack of maintenance on dryers. Pull it away from the wall and unplug it. Check the inside of the duct work and clean it out. Then check the inside of the drier connection too. Run it without the duct connected and see if you have good air flow.
Jun 16, 2013 | Bosch Nexxt 500 Dryer
Bosch Nexxt 500 series dryer
Make sure the vent outside isn't blocked either.
May 21, 2012 | Dryers
Bosch nexxt 500 series dryer producing intermittent gas smell when running. wife says the smell has even permeated the clothes a time or two, but I haven't noticed it. heat exchage box? if so, how hard...
A few things to check...
First, check that the dryer vent is not clogged. You'll have to go outside to check. If you are not sure of a clog, disconnect from inside and have your wife hold a flashlight by the vent, then go outside to see if you can see it. This will also cause laundry to dry slower than it used to (your wife may have a feeling if this is the case).
Second, make sure you don't have negative pressure in the house (large house fans are good for cooling but move too much air out so the dryer cannot vent its exhaust gasses well). You can check by opening an exterior door about an inch and check if it swings open with a gush of wind. Even houses without whole-house fans can do this if you have enough bathroom fans and furnace fans going.
Third, If it is a smell of natural gas, then you should call a service technician because the valve is not opening/closing correctly (or fast enough) if you have a pilot-less starter.
May 05, 2011 | Bosch Nexxt 500 Dryer
The drum of my dryer is scraping against the outer wall and making a horrible noise
has the small wheels that hold the drum in place while it is running or a bolt somewhere has come loose causing this to happen
Mar 04, 2011 | Bosch Nexxt 500 Dryer
On my Bosch Nexxt 500 Series Electric Dryer keeps shutting off and gives the E-01 error we have check the exhaust air duct on back of the dryer and we have vacuumed the inside bearing shield what else...
Motor won't work
Lint screen hi-limit (thermal cutout) tripped.
Clean lint screen and clean lint and other debris from front shield, then replace hi-limit. Also check exhaust duct length & # of elbows.
Wire harness failed.
Run resistance or continuity checks to track down broken wire or connector. Replace failed wire harness.
Display shows "E:01" during drying.
Lint filter, air duct or air damper is blocked.
Air leaking past felt drum seal.
Air duct is too long, too small or has too many bends. Inadequate ventilation around dryer (i.e. in a closet).
Clean out filter, air duct and air damper.
Replace felt drum seal. If seal doesn't fit snugly onto drum, wet felt and dry it by running a timed dry cycle for 20 minutes (felt will shrink and fit drum snugly).
Shorten, enlarge, reroute and reduce # of bends in air duct. Move dryer to an area
Jan 09, 2011 | Bosch Nexxt 500 Dryer
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Ticking getting worse!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
edgfd
Sep 30, 2009 | Bosch Nexxt 500 Dryer
The dryer (Bosch Nexxt 500) makes a loud grinding noise when rotating. Any idea what this may be?
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Sep 26, 2009 | Bosch Nexxt 500 Dryer
Audiovox Bosch 718 World Cellular Phone Logo
143 people viewed this question
Top Audiovox Cell Phones Experts
Spud Howell
Computer Repairing
Computer Repairing
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
