Question about Car Audio & Video
I GROUNDED OUT THE RED AND BLUE IGNITIONWIRES ON MY 2000 MODEL SUZUKI KITANA 750 NOW I HAVE NO POWER WHEN I TURN MY KEY ON
    New Friend:
  • 61 Answers
If it is fuel injected check your management box
Posted on Jan 06, 2014
2000 hadlights won't turn off
2000 GV relay stuck HL relay 2 stuck, or commanded on in error.
bad wiring
bad switch to relay . stuck on,
wire grounded out there.
FSM covers this for 4 bucks
https://suzukipitstopplus.com/Category/3-suzuki-service-manuals.aspx
Mar 13, 2015 | 2000 Suzuki Vitara
F1 Flash on dashboard
put it in dealer mode... with key off, take off seat, find the white plug with a cover on it. take off the cover and using a paperclip jump the white and black wire in the slots, theyre at the top of the plug. turn the key on and turn the red ignition switch on. It will now display what the code is. just google the code that it displays
Oct 02, 2013 | 2000 Suzuki GSX-R 750
94 explorer no crank but starts when bridged at relay. changed bat. starter, relay, ignition coil/ switch/ and ignition, terminals, ground cable, fuse, black relayZ?????
Check for power on the red with light blue wire at the ignition switch with the key in the crank position. If there is no power make sure there is power on the yellow wire at the ignition switch. Also check to make sure the key is making the full turn to the crank position. If there is power than check for power on the Pink wire at the neutral safety switch on the side of the automatic transmission. If there is not power I need to know if you have the anti-theft system or not. If there is power than check for power out of the neutral safety switch on the red with light blue wire. If there is power on that wire pull the starter relay and check to see if two pins are grounded all the time. One of the other two pins that are not grounded should have power all the time. The other pin should have power when the key is in the crank position. That should get you started. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Jan 11, 2012 | Cars & Trucks
Ok here we go i have a 2000 chrysler sebring that i for the life of me cant find the fuel pump relay (yes i have checked both of the fuse panels and nothing is labled for the fuel pump) there is a block on...
Of the 3 relays, one is the Fuel Pump Relay . wires are White/Red, Black/white, Red/black, Black/blue. Black/white and Red/black should have power with key on. Black/blue powers the fuel pump. The computer grounds the White/red to turn the relay on.
Aug 31, 2011 | 2000 Chrysler Sebring
2000 gsxr 750 y its been sat for only about a month and will not start. battery is fine and charged all lights at full power when key is turned but when i press starter nothing. never had a starter prob...
Have you checked the side stand switch is in the up position, and the plunger is not sticking , you hav e pulled in the clutch lever , checked the wires have not come of the clutch safety switch, at the solenoide jump the two thick wires with some insulated pliers, this will put power direct to the starter and it should turn the engine over and start, if the imobiliser if fitted is not holding it off, this will then rule out a problem with the starter motor and solenoide circuit.
Apr 30, 2011 | Suzuki GSX-R 750 W Motorcycles
I started my 92 gsxr 750 today and let it idle for a while then I turned it off with the kill switch .but forgot to turn the ignition key off.went in side for about 30 min .then came back out to start it...
By leaving key on you killed battery.Charge up battery and if dosent take charge, need new battery.Motorcycle batteries dont take much to kill,exspecialy if it is more than 3 or 4 yearts old.
Mar 06, 2011 | 2000 Suzuki GSX-R 750
Where is the relay switch on a 2001 gsxr 750 suzuki motorcycle
Iv got a gsx r750 1999 model but it wont start lights come on when I turn the key but the horn dont work neither does the start button to turn over the engine....i did notice a lil black box missing next to the fuse box could that be the problem???....if any 1 could help id appreciate the answers
May 26, 2010 | 2000 Suzuki GSX-R 750
One day tried to start 1996 suzuki katana,turned
I would be checking main fuse not much more it can be
Jan 10, 2010 | 1996 Suzuki GSX 750 F (Katana)
Checking power to fuel pump 1998 gsxr750w
Yellow and red wires should be your power wires, the others should be ground. Check for both. You may need to turn it over a few times to get the pump to prime.
Jun 09, 2009 | 1998 Suzuki GSX-R 750 W
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
