Question about Pioneer "AVH-P6300BT Bluetooth DVD Player DIN 7"" LCD Touch"
Static radio - Pioneer "AVH-P6300BT Bluetooth DVD Player DIN 7"" LCD Touch"
When I try to find radio station all I get is static. How do I use radio function
You need to have an antenna to have your radio stations come in clear. If you just hear static, your antenna sounds like it's not there!
Feb 16, 2016 | Eclipse Audio Players & Recorders
Why do radio stations have static?
Why are all my radio stations static? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Feb 20, 2014 - on all of the radio stations in my car, there's a static background noise. no ... It sounds like the receiver has lost it's sensitivity. either that, or the ... Why am i still getting static on my radio?
Sep 16, 2013
Why are all my preset radio stations static?
Sep 3, 2012
Why do AM radio stations have so much interference and static ...
Jul 2, 2009
My car radio makes so much static noise with engine running, but ...
Jan 17, 2007
More results from answers.yahoo.com
Dec 12, 2015 | 2005 Dodge Durango Limited
Any ideas about loud radio static?
Not the Radio. \Static is a result of a short. Could be a speaker wire, insulation or bared surface. Connection not good, or even the radio antenna out of phase.
Mar 06, 2015 | 2005 Buick Rendezvous
Radio static issues
Antenna Problem
Gounding Issues almost anywhere
Alternator Diodes Bad
Those problems are usually the result of the
last person to work on it
Mar 07, 2013 | 2008 Chevrolet Hhr
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
How too reduce the static noise in a 93T galaxy radio
doesn't make a difference what radio,if you have static it will be in them all . Buy yourself a noise clipper ,about 27 $$$ and that should help you with the static.
Jun 15, 2012 | Galaxy Radios DX-93T Base CB Radio
I have a lot of static when i'm listening to AM radio on my bose radio
FM reception is good; however there is a lot of static on AM 1000. No problems on other AM stations. Any suggestions or than stop listening to "1000"?
Nov 24, 2009 | Bose Wave Radio
Only get static when trying to receive transmission
Turn the squelch knob eathier up or down to eliminate the static.
Oct 14, 2008 | Audiovox FR2302 2-Way Radio
GALAXY 88 HIGHT STATIC IN THE RECEIVE ..
If the antenna for the other properly operating radio is used with the radio with the noise and you are getting the static then we can assume it is the radio. If you hear signals with the static, that is, it does receive communications at the same time, there may be a problem with the noise reduction circuitry, or a defective component(s) in the receiver. Without knowing your experience I would suggest taking to a radio shop.
Oct 10, 2008 | Galaxy Radios DX- 88HL Base CB Radio
I get static after someone else talks
One of the main causes of static can be a bad battery. If you are using rechargeable batteries you need to replace them every 14-18 months. If you are using alkaline batteries, they have been known not to fully power the radio once your cross the 10 hour mark. Your radio would then be operating in somewhat of a brown out. This would lead to static.
Another cause of static is simply being nearly out of range of the other radio(s).
The burst of white noise at the end of Rx on some radios can be rather annoying. On the basic talkabout radios there is nothing which can be done to solve the problem, other than replacing the radio.
Jul 26, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Pioneer "AVH-P6300BT Bluetooth DVD Player DIN 7"" LCD Touch" Logo
16 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
