Toshiba 56hm66, lamp replaced but lights still blink
Got the tv from a friend from college right before black friday and it worked great, but about 2 weeks ago the lamp went. Nbd; get the new lamp, slide it in, easy peasy. Now however when i turn on the tv it tries to act normal, screen goes bzrt and i can hear a circuit or something click and the fans kick in but theres no picture (unsure about sound). It will cycle for about 2-3mins thru trying to startup and turning off, power light blue and alone for ~10secs and then solid blue pwr light and the lamp light blinks yellow every 1sec. Sometimes between startups the blue light will go out and the yellow quickly blinks ***-***-*-*. When the tv gives up at last the lamp light is solid yellow and the standby(i think, this lights unlabeled) flashes red. I did manage to get the tv to speak to me, trying to explain thats there's still a problem with the lamp as it begged me to call Toshiba support. Now i have the back panel removed, most of the wires double-checked and a majority of the dust removed, but what should my next move be?
  • 468 Answers
Check the circuit boards to see if any have failed. They are small cylindrical objects. If the tops of any of these are bulged instead of flat then they are bad and board will have to be replaced. Hope this helps.
Posted on Jan 04, 2014
  • 178 Answers
SOURCE: KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
Posted on Sep 02, 2009
BMW Rider
  • 232 Answers
SOURCE: TV doesn't turn on
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
Posted on Nov 28, 2007
  • 179 Answers
SOURCE: I have a Mitsubishi WD-62525.
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Posted on Nov 17, 2008
ginko
  • 19396 Answers
SOURCE: toshiba 46H84 tv turned off light blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
SOURCE: toshiba 56hm66 yellow light blinks 15 times
unfortunately I don't have any solutions for you. I have just started to have the same problem and have only replaced the lamp. i was going to move on to the ballast but wouldn't want to if it going to be a waste of time. Did you ever find any way to resolve the prolem?
Posted on Dec 06, 2009
THE YELLOW LAMP LIGHT KEEPS BLINKING NO OTHER LIGHT IS ON AND I JUST CHANGED LAMP
Did you use a Toshiba lamp--Toshiba sets will NOT work right with a generic !!
Mar 27, 2014 | Toshiba 56HM66 56" Projection HDTV
The tv worked for about 30 minutes now the screen is blank but sound is still working and the lamp light is blinking, what do i need to do to fix?
bigjohnson4,
It sounds like you need to replace the lamp and perhaps reset the unit. I have tips to cover all of the problems.
How to replace the lamp:
http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv
What to do if the unit will still not work:
http://www.fixya.com/support/r8482944-after_lamp_replacement_projection_tv
How to reset the lamp: Using the FixYa seach engine, input "Lamp reset procedures for (your manufacturer)" and you should get the proper procedure.
Thanks for using FixYa and for the great rating.
hardrocko
Feb 28, 2011 | Toshiba 56HM66 56" Projection HDTV
I'm getting a rainbow tint on the upper 1/5th of
usually when the lamp is going out the picture gets dark if you are getting a rainbow tint most likely the light engine is going bad.
Aug 17, 2009 | Toshiba 56HM66 56" Projection HDTV
Toshiba 56hm66 yellow light blinks 15 times
Jul 09, 2009 | Toshiba 56HM66 56" Projection HDTV
Toshiba 56hm66 New lamp worked last night, wont boot up again
You now have a defective lamp ballast board. It sometimes is the root cause of lamp failures in these sets. The problem here is that Toshiba does not sell the ballast board independently from the larger, more expensive light engine assy. Call Best Buy back and get a servicer out there. He may have to take the ballast board out of your TV and send it out for rebuilding.
michtech
Feb 12, 2009 | Toshiba 56HM66 56" Projection HDTV
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
