Question about Toshiba 46SL417U - 46" class 1080p 120Hz LED TV
Toshiba tv model no 46SL417U will not turn on. there is Clicking sound and three green blinking lights when you try to turn it on.
Will not turn on.
dwn4lf
SOURCE: toshiba 46H84 tv turned off light blinking
Sounds like a problem w/ the red tube.
Posted on Jan 07, 2008
ginko
  • 19396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
SOURCE: Blinking Yellow light on a HD 65" DLP Toshiba TV
I have a 56 inch tohiba DLP (56 HM 195). Replaced the bulb for the second time this year. last time only lasted 3 months. TV is tough to turn on. When I get it to turn on, and then shut it down, the yellow light blinks constantly for 5-7 mintues. Then it shuts down completely. Is the set overheating? There is nothing in the manual that speaks to this issue. thank you
Posted on Aug 15, 2009
hawk127311
  • 350 Answers
SOURCE: I have a Toshiba DLP Projection TV model # 44N
It is an error code. Count the flashes and then re-post asking what the amount of flashes means and how to repair it. Make sure you post make and model of TV.
Posted on Dec 03, 2009
SOURCE: No Picture on Toshiba 42RV530U
I had a similar problem to this yesterday. Tv is same Toshiba model as you mentioned about 4 months old. In my case, after the TV working perfectly following installation, the standby LED on the front (the one that is red on standby and green when on) went to a flashing orange (after switching on from standby) and the picture disappeared although the sound remained OK. I was unable to get any response from the setup or menu on the remote, otherwise I would have tried resetting the TV. Regardless of how much switching off/on (including disconnecting the powerlead and leaving for few minutes), disconnecting all peripherals, etc., nothing helped. I looked up Toshiba's web site and under support they basically suggest switching off the TV and restarting using the onset buttons (not the remote) and pressing the menu button (again the one on the set (not the remote) and if you could get the menu box to appear then reset to default settings. I tried this but the results were the same. I therefore thought the TV was defective. However, after much frustration I did the following (I think): 1) Disconnect everything from the TV 2) Powered up from the mains switch whilst keeping BOTH the startup and menu buttons on the side of the TV pressed down. The result in my case was that the standby led and one of the two beside it flashed green simultaneously. However, when the buttons were released, the TV started up the same (flashing LED orange and sound no picture). 3) Pretty well defeated at this point, after doing the procedure at (2) several times with the same results, I somehow thought of pressing the standby button on the remote either whilst the two buttons on the set were depressed or just after they were released. I am afraid I cannot remember which and cannot replicate the problem as I don't know what caused it in the first place. 4) The TV then started normally ( no reception as I had not aerial connected, etc.,) but I was able to gain access to the screen menu/setup buttons via the remote which were in French rather than English. However, after reconnecting everyrthing the TV has worked fine (obviously after resetting the language via the menu). I am sorry I cannot be more precise but I hope this might be of help to someone with a similar problem.
Posted on Dec 22, 2010
You turn on the TV, the green light flashes 3 times, then flashes three times again. It turns on great picture, you can open the menu, change sound up or down or mute it. Then about 15 seconds later you...
have you had the freeview board off and used tv with it not on. sometimes the built in free view board can fail and use the processor speed up. so no menu etc also will affect the inputs..
Oct 01, 2013 | Toshiba 46SL417U LCD TV
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Oct 04, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
NO picture no sound
blinks three times?, do you hear any clicking?
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 46SL417U - 46" class 1080p 120Hz LED TV Logo
62 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
