Question about Riso Office Equipment & Supplies
Riso RZ 220UI shows horizontal bars
I ran our Riso RZ220UI in test mode and printed out a checkered sheet and square sheet and they printed flawlessly. When I scan something, however, I have a series of solid bars on one end of the page, slightly varying in thickness and space apart, but same length. It is being burned onto the master. Cleaned glass, put white posterboard behind scanned item... same bars in the same part. It is a scanning issue but I can't figure out what to clean or how to fix.
  • Jason Wessendorf
    Jason Wessendorf Jan 03, 2014
    I just looked at the scanner going across and the little green LEDs blinking in exactly that part and in the frequency that makes me sure it is the cause. What to replace?
    New Friend:
  • 58 Answers
You have to change the whole unit of your led light. the bar with all those led lights are attached or soldered. hope to be of help.
Posted on Feb 14, 2014
MUKHTAR
  • 2022 Answers
SOURCE: Test Page
align the catridges
Posted on Sep 22, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Posted on Oct 27, 2007
MUKHTAR
  • 2022 Answers
SOURCE: Yellow line showing on in scanned pages
if you can open the cover of the scanner just clean the glass and use any lubricant to apply on head rod to move smoother .
bye
Posted on Nov 16, 2007
SOURCE: HP PSC 2410 very slow printing issue
It is a cartridge problem. Solution for my hp 3645 (I have the same story as bb18, but different printer) was to remove color cartridge!
The printer is fast now, of course it does not print in color :) (I`m waiting for a new color cartridge) Good luck,
Marcin
Posted on Feb 08, 2008
CWChar
  • 14 Answers
SOURCE: Vertical lines when scanning using automatic document feeder...Glass is clean
It is not in the glass. More than likely it is in the rollers of the ADF feeder. If you open the cover of the ADF feeder you can see there are 3 screws (! is found under another small cover furthest to the back of the machine. Once these three screws are removed you can left the entire ADF feeder from the unit. You will then be able to clean all the rollers. Do not use alcohol as this will dry our your rollers and cause them to eventually crack. Just use soap and water to clean the rollers. Then reinstall the ADF feeder assembly back on the machine.
Posted on Nov 14, 2008
How do you enter user codes on a riso RZ 390
by pressing print position keys Plus 15 & minus 15 at a time with one hand and by using other hand machine power on, and release both keys u will in test mode
Jun 19, 2014 | Riso RZ390 Duplicator
Riso rz 390
There should be a built in head cleaner. I think you can access it through the control panel, then device and printers. right click on the printer with the issue, scroll down to printer properties. there should be a box that says "print test page" when the test page prints it should ask you if it is ok, this is where the clean head should be.
Jan 18, 2014 | Office Equipment & Supplies
How do I print two 8 1/2x11 sheets of paper on a 11x17 sheet on the riso 220? It keeps cutting my originals off.
RZ 220s have a smaller print area on the drum. I think around 9x14. Although the 220s can take 11x17 paper they cannot print over the entire area. (This is why I personally went with a RZ390. It has the 11x17 print area) Sorry, you're out of luck pal.
Oct 25, 2012 | Riso RZ220 Duplicator
How to find a riso 220ui on network or what is the ip address associated with a riso or how can the address be determined?
go to driver downloads at riso.com and download the riso admin tool. much easier than the web interface. test mode/print 95 if you need a config sheet with ip, for example if your subnet mask still isnt letting you see it.
Jan 08, 2012 | Riso RZ220 Duplicator
I have a problem error fo115 of riso rz-220
F01-115 means no master on drum at start of printing. Make sure you make a master before trying to print.
Jan 20, 2010 | Riso RZ220 Duplicator
Riso RZ 220UI
1-need to find out if image is on the drum, make a copy and stop it open and look is there toner on the drum itself? yes then the problem is with the Seperation
2-No, then the problem is with the Transfer
Sep 05, 2008 | Riso RZ220 Duplicator
111 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
