Panasonic sa he70 f70 error code - Audio Players & Recorders
SOURCE: Panasonic SA-HE100 5.1 system error code F70
I was able to fix this problem by replacing a fuse. Remove the cover (7 screws). Directly behind the fan are 2 boards with 5 fuses on them. The boards are 1 over the other. The fuse I replaced was labeled F5 and on the top board with the fuse facing down on the underside of the board.
Posted on Jun 23, 2008
  • 4234 Answers
SOURCE: F70 ERROR ON PANASONIC AV RECEIVER SA-HE200
This is essentially a protection mode indication. Either the output amp pac is defective or the regulator circuit is bad. Either option could be over $75 in parts plus labor at a local shop.
Let me know if you would like to attempt the repair and I'll try to get you more specific parts information.
Dan
Posted on Mar 17, 2009
  • 4234 Answers
SOURCE: Panasonic SA-he75, displays an F70 error.
The F70 error is a code for "protect". See the link below for a general explanation of protect mode. Specifically for your unit, the output amplifier IC has failed. This can be replaced, but the parts cost will be in the $100 range. Please update this if you have further questions.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Oct 08, 2010
SOURCE: SA-DX750 error F70
I have a technics sa dx 750 receiver that cut...
Posted on Jan 03, 2011
ripleymojica
  • 643 Answers
SOURCE: Problem with the Technics SA-DX750
bad powersupply.
Posted on Mar 21, 2011
CD function not working on Panasonic SA-HE70 receiver
when you say its not working what do you mean by that?
its got no power.
the tray wont open.
tray trying to open but wont.
or just wont play cd.
if none of the above could you please give me more info please.
Nov 08, 2016 | Panasonic SA-HE70 Receiver
I have a button that allows bass/treble and balance but only balance works regardless of how many times you press it.
Read Page 13 of your owner's manual http://www.manualslib.com/manual/119549/Panasonic-Sa-He70.html?page=13#manual
Jun 06, 2015 | Panasonic SA-HE70 Receiver
Am looking for a manual for an SA-HE70 av control manual
Crutchfield has the manual for the Panasonic SA-HE70 on their product sale page: http://www.crutchfield.com/S-6TiEMal3qmL/p_133SAHE70K/Panasonic-SA-HE70-Black.html . Look at the Details tab. The direct link to the manual is http://www.crutchfield.com.edgesuite.net/pix.crutchfield.com/Manuals/133/133SAHE70K.PDF .
I hope this helps.
(You will need Adobe Reader or a similar program to read or print the manual.)
Apr 19, 2015 | Audio Players & Recorders
Its showing F70 error on display. Only workd on DVD mode, when i turn it on any other mode it just shows F70, switch power off. All fuses are ok, no any visibly damaged components
The fuse is a part of the problem it is for safety measures
the problem is in between the power supply regulators, capacitors and power amplifier circuit board.
usually a regulator or an output transistor can cause this error.
hope this helps.
Aug 08, 2014 | Panasonic SA-HE70 Receiver
What does f70 overloads means
Sounds like either an amp problem or a fan problem. Either one can send a F70 code. Check and see if the rear fan is turning freely, it might just be dirty and can't spin easy
Sep 22, 2013 | Panasonic SA-HE70 Receiver
Panasonic AV Control Receiver SA HE7 error code F70
solution about f70 on my amplifier to remove
Jun 07, 2011 | Panasonic SA-HE7 Receiver
How to hook up external amp need to know how to run jacks to the amp and speakers which out put for amp to run the front speakers on a panasonic sa-he70
Manuals help.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SA-HE70K-Receivers-manual/id/312ag701/t/2/
Not knowing anything about your 'external' amp or how you want it to function the only thing you could do is feed it the analog stereo output of the SA-HE70 from one of its OUTs (Tape or VCR). It won't be volumed-controlled by the SA-HE70.
Jun 01, 2011 | Panasonic SA-HE70 Receiver
Thanks,
Dan
Oct 08, 2010 | Panasonic SA-HE75 Receiver
F70 problem
Look up "Panasonic F70 error" on Google and you will find plenty of discussion about this problem.
The F70 is a blown fuse error. It looks like you can can the fuse yourself, if so inclined, otherwise send it to a service agent.
Aug 03, 2008 | Panasonic SA-HE70 Receiver
According to the operating instructions, you must take it to a repair facility. There are no troubleshooting suggestions for this problem in the manual.
Dec 15, 2007 | Panasonic SA-HE100 Receiver
74 people viewed this question
 Grubhead
Grubhead
