Question about HP Compaq Presario V5204nr Notebook
Driver side door won't open from the inside.
The driver side front door on my 2005 Nissan Sentra all of sudden won't open from the inside. You pull on the door latch and nothing happens. It opens fine from the outside. Is there an easy and cheap way to fix this?
  • 1 more comment
  • Chris Steer May 22, 2009
    manual door locks.
    I will try this and let you know. Thanks a lot!
  • Jim Goldsmith
    Jim Goldsmith May 11, 2010
    electric or, manual door locks?
  • 1,869 Answers
Remove the inside door panel reach inside and, reattach the clip to the inside door lever rod
Posted on May 22, 2009
In my case, I opened the door panel and found out that the part of the handle that opens the door from inside has been broken. This part did not let the handle to extend fully and pull the wire correctly. The broken piece fell off, the rest of the handle was intact and functioning, so I simply replaced the door panel.
Posted on Jul 09, 2009
Why doesnt my G37x sedan front doors open?
2009 Door Problems - MyG37
www.myg37.com/forums/g37-sedan/253409-2009-door-problems.html
Dec 6, 2013 - 2009 Door Problems G37 Sedan. ... My problem is that my front driver side door will not open up from the inside or outside. My FOB key ... door wouldn't shut....now it won't open
Mar 5, 2015
Help! my windows roll down when i open the door!
Apr 10, 2013
Rattle in drivers side front door
Dec 11, 2010
Window Reset
Jul 28, 2008
More results from www.myg37.com
Driver's side door won't open!? - G35Driver
g35driver.com/...sedan-v36.../371407-driver-s-side-door-won-t-open.ht...
Mar 24, 2011 - I went to get in my car today and my driver's side door won't open - from inside or out. There's. ... The manual locker inside doesn't work. Problem with driver side door locking (and unlocking)
May 3, 2011
Dome light issues
Jul 3, 2010
More results from g35driver.com
Drivers door would not open - Nissan Forum ' Nissan Forums
forums.nicoclub.com/drivers-door-would-not-open-t466851.html
Dec 11, 2009 - My wife went around to the drivers side and used her key to see if she
Jan 27, 2016 | Cars & Trucks
My 06 sentra driver door won't open from outside or inside so i can't take door panel out unless i open the door please help
Idea - open up the passenger side door and see how the locking mechanism works. Then with a coat hanger devise a tool to open the door.
Then using same tool apply same technique to driver side door to open and repair.
Sep 08, 2015 | 2006 Nissan Sentra
I need a diagram of the locking mechanism in my 2001 nissan sentra so that i can use a slim jim to unlock the passenger side door.
I don't have a diagram of the door but if you slip the slim Jim in over the top of the outside door handle it should catch on the latch bar. If you are doing this because the door won't open from the interior handle or the outside handle the problem most likely isn't the lock. The way that handle connects to the release it is held in place with a piece of plastic that breaks fairly easy. If that piece breaks the interior door handle won't activate the unlock function when pulled and you will have a heck of a time getting the door opened so you can get inside the panel to do the repair.
Oct 05, 2011 | 2001 Nissan Sentra
2006 buick lucerne back doors won't open
My friend just had this problem and he reached in and pulled the inside door handle back as far as it would go, and then let it go, allowing it to 'snap' back. For some reason this fixed it. We have no idea why. By doing this on one door, both rear door locks freed up and the rear locks are now working. Before, both rear locks were stuck and you could not open the doors from the inside nor the outside. Not sure why it works, but maybe it will work for you!
Jun 10, 2011 | 2006 Buick Lucerne
I can not open the driver's door from the inside on my 2006 Nissan sentra but it can be opened from the outside. Need help
BECOS YOU HAVE DIFFRENT ARM ROD FOR THE INSIDE AND THE OUT SIDE TAKE OFF THE PANEL AND YOU WILL SEE IT WHEN PULL THE INSIDE PANEL OFF ,PULL THE HANDLE AND YOU WILL SEE WHERE IT SUPPOSE TO BE AND JUST REPLACE IT
Mar 10, 2011 | 1994 Nissan Sentra 4-Door
How do i fold down my rear seats in my 2005 nissan sentra?
There should be a little knob inside the trunk that you have to pull. I think its on the driver's side. Once you release that knob you can lift up the backseat recline thing on the back driver's side seat and it folds down. Hope this helps.
Jun 12, 2010 | 2005 Nissan Sentra
2004 nissan sentra the driver side door lock
most likly need a door lock actuator for drivers door
Mar 20, 2010 | 2004 Nissan Sentra
Tire size on 2005 Nissan Sentra
1.8 and 1.8S ---- 195/60-15
SE-R ----
195/55-16
SE-R Spec V ---- 215/45-17
Aug 13, 2009 | 2005 Nissan Sentra
Installing a Nissan Sentra Passenger Side Manual Non Folding Mirror.
had to install a driver side non folding mirror, fairly simply to say the least. There's a cover on the interior of the door, near the window, remove the cover, remove the 3 screws, need i believe a 10mm socket. If a power window, unhook the circuit. Replace new mirror.
Jul 28, 2008 | 2005 Nissan Sentra
HP Compaq Presario V5204nr Notebook Logo
225 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
