Question about Lexmark JetPrinter X1185 All-In-One InkJet
Print spool error 1068
While trying to install software for printer it wont let mego any further than print spool not running
  • 59 Answers
A 1068 is a service dependency error. Print Spooler can't start because it thinks a service it depends on is not running.
click Start, then click run. Type in "services.msc" without the " " marks
Go into services and check its dependencies, it should just be the RPC service, which you shouldn't be able to stop, check that RPC is running
Double click print spooler and click the dependencies tab. See if there are any other dependencies set besides rpc. If so you will want to find them in services and make sure they are set to automatic and are running (will probably need to start them).
Then try to start "Print Spooler" service, should work. May need to reinstall printer drivers then.
Posted on Oct 19, 2007
  • Steve Bryant Oct 19, 2007
    if that doesn't work, i got this from the net
    When Lexmark printer software is installed, oftentimes it installs a service
    (I believe it's called LEXBCS) upon which the Print Spooler service becomes
    dependent instead of being dependent on the Remote Procedure Call service
    (RPCSS). Unfortunately, when you uninstall the printer software the service
    dependency does not revert back to RPCSS.
    To change the dependency back to RPCSS, open a command prompt window and key
    in the following commands, pressing ENTER after each command (it may take a
    few second for each command to be successfully processed):
    net stop spooler
    sc config spooler depend= RPCSS
    net start spooler
Cant start printer spooler error 1068
This is caused when there are still printer jobs in the Windows spool. To manually remove these print jobs follow the below steps.
  1. Click Start, Settings, Control Panel.
  2. In the Control Panel double-click the Administrative Tools and then Services.
  3. Within services locate Print Spooler and right-click it and select Stop.
  4. Once this process has been stopped leave the windows open and open My Computer and browse the the below folder.
  5. In this folder delete all the files in the PRINTERS folder. Once these have been deleted you can right-click the Print Spooler in the Services window and click Start to re-enable the service.
If this does not resolve your issue it's likely you have an issue with your printer drivers you have installed for your printers and/or you have a trojan, virus, or worm infected on the computer.
Dec 12, 2010 | Brother MultiFunction Center MFC-440CN...
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using
Jan 27, 2009 | Office Equipment & Supplies
HP print spooler problem and error 1068. Want my printer back!!!
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
Nov 23, 2008 | HP PSC 1610v All-in-One Printer
Print Sooler not installed
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Nov 08, 2008 | Dell Inkjet 720 Printer
right click on my computer -> select manage -> one should be services and something (or something like that) open that and go to services -> find the printer spool service and right click on it -> click on properties -> in the printer spool service properites click the "Start" button and also under a drop down menu change it from "Disabled" to "Automatic".... This is what you did right ?
Log in to Administrator account and try it there. If that doesn't work then install a fresh copy of Windows Xp. It should work now. Thank you.
Sep 07, 2008 | Office Equipment & Supplies
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn’t work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click “Print Spooler”. Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you’re lucky, this might be all you have to do. Still doesn’t work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer’s software from the manufacturer and reinstall it. get more information for printer spooler error .Hope this helps you.
Mar 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Print spoole
has this been resolved?
Jan 10, 2008 | Dell A920 InkJet Printer
Try this FixYa for Error 1068.
Let me know how it goes.
Jan 08, 2008 | Dell A920 InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
69 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
