Question about Wolff Sunquest Pro 24RS 220 Volts
I have a sunquest 24rsh bed, the bulbs go out after about 1 minute, I have replaced the timer and the bulb starters, the fans continue to run
The fans continue to run, could this be the relay?
3 Suggested Answers
SOURCE: Where do I find replacement trim profile for my Sunquest Pro 16 SE tanning bed
Ebay has several:http://compare.ebay.com/like/350311266168?_lwgsi=y&ltyp=AllFixedPriceItemTypes&var=sbar
Posted on Mar 02, 2012
SOURCE: My Sunquest, Pro 24RS.
ballast is about the only thing left its hard to check anything electrical without a volt meter it could also be the bulb holder
Posted on Feb 09, 2013
I have a Sunquest Pro 16s tanning bed. I just put all new bulbs in and tanned 2 times then it quit working. the timer is still going but the bulbs went off and the fan stopped.
Have you checked to make sure the bulbs are inserted properly? If everything checks out well I would contact Sunquest customer service.
Jan 09, 2018 | The Health & Beauty
I have Sunquest Pro 16s tanning bed that I have just replaced all of the bulbs. One will still not light. Can anyone help?
There are no starters on the 16s. Did the position work before you replaced the bulb? If not and it still doesnt work with the new lamp, it is either a lampholder or ballast. If it worked before and doesnt now, it is either not in correctly or its a bad lamp, you can verify by swithching with another lamp
Jun 03, 2016 | Health & Beauty
Accidentally plugged a 110 tanning bed into a 220 outlet. What may be damaged?
Actually the lights them selves might be damaged or the ballasts that start them. I do not know how you can test them. But if you look at the ends and they are black that is not a good sign. if they are the same shade from end to end thats good, the next thing might be the ballast's or starters. I do not expect you to have starters but they would be cheaper and easier to change if you did. To find the ballasts you would need to disassemble the bed. they would most likely be located between the lights and might power two four or eight lights each. and be connected to many wires. all leading to the lights at each end and the power supply. unplug the bed before you start they will be heavy and usually black color does not matter but they will be heavy. unless they are starters.
Sep 14, 2014 | Wolff Sunquest 14SE Tanning Bed
I have a Sunquest Pro 24S four upper bulbs went out together. I changed bulbs and starters. What else can it be?
Assuming the ballasts are good, Do a continuity check on the tombstones. If one stab wire arcs out, it could daisy chain down several bulbs. You can also wiggle the wires at the tombstones and see if the bulbs light up. If you replace tombstones, be sure to select the same style shunted or unshunted (electronic ballasts will be shunted).
Aug 11, 2014 | Home
Sunquest pro 16 se
You may have a wire burned out going to that set of ballasts/bulbs. Have a trained technician to check and repair this.
Feb 08, 2013 | Wolff Sunquest Pro 24RS 220 Volts
How to remove and install ballast in sunquest 24 taining bed
I have a question for someone who knows about a Sunquest 24 r tanning bed? Involving bottom bulbs not lighting at all?
Feb 02, 2013 | Wolff Sunquest Pro 24RS 220 Volts
2003 SUNQUEST PRO 24RS MANUAL TANNING BED
I Have a m2 24rs8 tanning bed. I loved it . I have moved it was in storage for 2 1/2 years. Moved to a new house. I hooked my bed up. the only thing it does kinda turn the fan on. what have I done wrong....It is on a 20amp bracker. Wire is 12 2 with ground. HELP PLEASE
Aug 25, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wolff Sunquest Pro 24RS 220 Volts Logo
27 people viewed this question
Top Wolff Health & Beauty Experts
Steve
NOEL
NOEL
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
