F42 valiant fault code - Computers & Internet
WAT DUSE F42 MEAN ON A BOSCH WASHING MACHING
It could mean there's a fault with the motor
Source: Bosch Error Codes Page
Dec 14, 2016 | Bosch Washing Machines
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
F42 is showing on my Bosch Logixx 8 sensitive washing machine what does this mean and how do I fix it . thanks
An error code of "F42" means your oven has a defective or jammed lower latch, latch motor or latch switch, which is preventing the lower oven's latch from locking properly. If all of the electrical connections are in place on your oven's power board, you may have a faulty power board.
Apr 01, 2011 | Bosch Washing Machines
Its a vaillant condensing gas boiler, it is showing problem with ignition, it won't fire up. fault code 28
f:28
air in gas
gas rate low
could be gas valve faulty,ignition transformer,ignition cable.
if there is a spark then its your gas valve,if no spark then check continuity on harness and spark generator,also check earth to appliance
Oct 19, 2009 | KDS Valiant 6380iPTD-01 Notebook
Valliant ECOmax boiler is not giving me any hot water
My Valliant Ecotec Pro Combi Boiler (approx 4 years old) does not start up. The fault code showing is F.22. I would be grateful if you could let me know what the problem is and obv how it can be fixed. Thanks and regards, Joanne Byne
Jul 03, 2009 | KDS Valiant 6380iPTD-01 Notebook
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
