Question about Drills
Drill into tile
How do I drill into tile without cracking it
2 Suggested Answers
  • 39 Answers
SOURCE: How do I fix a cracked ceramic tile
I would try breaking the tile up with hammer instead of prying from side, as you maybe chip or crack adjoining tiles. This method should work fine, you may loosen surrounding tiles but just re-mortar any tiles that may become loose. Wear eye protection. Good luck
Posted on May 23, 2012
Testimonial: "Thanks, like it when hammer is tool of choice."
How do you drill through ceramic tile
Go to Lowes, Home Depot, Menards or reasonably good Hardware store. buy a ceramic bit. They are usually with the wood, steel and concrete bits. Small bits arent to pricy. If you need a larger hole like the on the shower pipe goes through, you will need a ceramic hole saw. Hole saws are coated with diamond chips and will probably cost $40 or more. good Luck
Oct 08, 2015 | Porcelanosa Ceramic Wall Tile: : Mosaico...
May 19, 2012 | Home
Getting ready to install the Moen DN2160 Curved shower Rod. In reading through the instructions I am confused about what is necessary to install in a tile shower
hi doug. the only issue with tile is that drilling holes in tile requires a special tile cutting drill bit. These are common. I got some last week at a home depot. J.
Jul 08, 2011 | Moen Home
Hi, I want to replace an old American Standard toilet bowl that is a 4 bolt tie down design to the floor. Can I replace this with a standard 2 bolt floor mount design? If not are 4 bolt tie down models...
If you go with the 2 bolt you will need (I presume) to drill 2 holes into the tile. put toilet in place where it will sit and mark the holes , take away toilet and drill the holes with a 7ml tile drill bit (masking tape put over the tile will help you to not slip when starting off the hole). Drill deep enough to insert 7ml rawl plugs. then place the toilet back and fix down with screws long enough to go through the toilet and 3/4 of the rawl plug. You will need; Electric percussion drill or descent battery drill. 7 ml tile drill bit 2 x rawl plug 7ml 2 x screw masking tape is handy hope this helps, Alex
May 18, 2011 | American Standard 2294.011.020 Afwall...
We are concernened about screwing the tub into the floor for stability. We have to go through tile and into wood. There are no instructions included for this. Included were 5/16 lag bolt and feet but we do...
The main reason to screw the feet to the floor is to keep the tub from moving which could cause the pipes to leak (either the supply or the drain) Authentic old clawfoot cast iron tubs were usually bolted to the floor because they were so heavy that it took a significant effort to move them, especially on a wood floor. If your tub is light enough that you could move it without a pretty significant push, then you had best bolt it to the floor in at least two places. Drilling holes through tile can be intimidating, but it's not as hard as you might think using an inexpensive masonry drill bit and a carbide tipped scratch awl. I will leave it to you to figure out how to assemble the claw feet to the tub, but here are a couple of important tips for drilling the holes through tile: Mark the hole locations with a felt-tip marker. Then use the carbide tipped scratch awl to gouge a starter divot in the tile. This divot can be pretty small, but it's essential for being able to drill a hole in tile in the right place. Use a variable-speed drill at fairly low speed to drill the hole - don't use a hammer-drill. Also keep a puddle of water where you are drilling to prevent the tile from heating up in one spot and causing the tile to crack. Once you get the hole through to the wood below, switch to a regular drill bit of a smaller size. Good luck, Al K
Aug 24, 2010 | American Standard Reminiscence...
I have crack in my shower floor concrete, would like to fix it before laying tiles and hope it won't be visible after i am done with tiles. I had tiles before wich I am removing now and will instal new...
There is a tile backer, kinda of like fiberglass mesh, I have also seen a waffle looking plastic, that will go down over the crack in the floor and will not effect the tile one bit. You just tile over everything, no mastic, no set under this stuff, no fasteners, just tile over it like a normal floor, and the best part is, no crack! Hope this helps.
Jun 29, 2010 | Plumbing
Adhesive for granite tiles on kitchen counter?
Mortar, go to a tile supply store and ask for the best tile mortar for granite.
Glue is fast and easy but pails in performance to that of mortar.
Jan 03, 2010 | RTO 5/16" X 4" Long Groo V Tip Granite,...
Applied dark brown glass tiles and those that were cut with a wet diamand blade saw are darker in colour to the others. will cut tiles become the same colour as other non cut tiles?
THIS COULD BE CAUSED BY 1 OF TWO THINGS, WHEN YOU USE WATER TO CUT ANY TILE YOU ARE INTRODUCING WATER TO THE INSIDE OF THE TILE WHICH WILL CAUSE THIS DARKENING OF THE TILE, 2ND WHEN YOU WET CUT USE A SLOW LITE PRESSURE LET THE BIT DO THE WORK TO MUCH PRESSURE AND NOT ENOUGH WATER WILL CAUSE OVER HEATING AND DARKEN THE TILE. HOPE THIS HELPS. ALSO
THIS DOESN'T ALWAYS WORK BUT AFTER CUTTING PLACE TILE IN A HEATED AREA TO DRY OUT THE WATER ,THE GLAZING IS WHAT PROTECTS THE INSIDE
Dec 01, 2009 | RTO 1/8"wet Diamond Glass, Tile, Stone,...
Drill hole in China Plate
Normally you would use a masonry bit to drill into ceramics eg tiles or bricks. if the plate is glazed it is better to stick some masking tape or adhesive backed paper on the area to be drilled to stop the drill bit slipping around. also i would be inclined to use a hand turned drill or a small battery powered drill if you have one to avoid breakage of the plate.
Oct 13, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
27 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
