Question about Hitachi Televison & Video
TV OVERHEATS ABOUT EVERY 30 MIN
AFTER A FEW HOURS OF WATCHING THE TV KICKS OFF, UNPLUG AND TURN IT BACK OH THEN IT DOES THE SAME THING ABOUT EVERY 30 MIN
  • 597 Answers
POWER BOARD
Posted on Feb 02, 2014
SOURCE: Powers off by itself.
Has anyone gotten a resolution for this the only answer I saw was the SSB Board. Is there a cheap place to get parts. Philips model 50P8341 goes off by itself also wont come back on if you unplug it for a while it will come back on.
Posted on Nov 04, 2006
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
hawkwatcher
  • 67 Answers
SOURCE: samsung hlr4266wx dlp tv shuts off
This tv usually if detects a fault will display via leds a error flash code. Refer to Owners manual for What the codes are for. If you go to Samsung Website Copy and paste link for manual.
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=televisions&group_cd=&type=televisions&type_cd=02010000&subtype=dlptv&subtype_cd=02010300&model_nm=HLR4266W&dType=D&vType=R&mType=&model_cd=&menu=download&prd_ia_cd=02010300&acc_ia_fl=N&disp_nm=HL-R4266W
Problem may be lamp is failing or ballast which operates lamp may be Bad. Could also be Temperature fault from Inoperable fan or Color wheel. Bulb of course is first choice of possible problem followed by color wheel then ballast. Color wheels usually will start making bearing noise when they start to fail. Hope this helps.
Posted on Jan 14, 2008
  • 3 Answers
SOURCE: Tv cuts off and green light flashes
The Best Solution worked perfectly, I replaced the XL2200 Sony Bulb and the TV is up and running again!
Thanks for the help.
BobE.
Posted on Aug 12, 2008
FreeTech
  • 426 Answers
SOURCE: pioneer sd-582hd5 shuts off while watching
internal components probably need to be cleaned.... sounds like a problem with t.v. overheating
Posted on Jul 11, 2009
Sony bravia 65 inch won't turn off
There is one main thing you need to do before any thing you need to unplug the Tv leave off for 24 hours not plugged in do not temp to plug it in then after 24 hours off you need to plug in do not try the remote or press any buttons ok at all just plug in and leave it for 24 hours plugged in then you can unplug the Tv for 30 mins then plug back in and try to use the remote or press the buttons if it still don't work then the power board might be the problem but get back to me afthe 2 days ok to see how you got on
Jul 10, 2017 | Sony Televison & Video
50'' hp no picture just color lines
Likely to be main board issue which is the most expensive board in set and also not likely to be a do it yourself repair.
May 20, 2012 | HP PL5060N 50 in. Plasma HDTV
Shut down while watching movie
Most likely a YLOD problem.
This problem occurs when that PS3 Unit overheats and the GPU or CPU becomes UN-soldiered from the mother board. the only way to repair this is by a re-flow of the soldier under the chips on the board.
This needs to be done by a professional due to the extreme sensitive nature of the internal electronics. There are a few repair services out there. I have been doing these repairs for a few years now and it usually takes me about 2 hours to repair a unit and then I like to test it for 30 hours to make sure it won't overheat anymore.
you can contact me by email if you would like me to fix your unit for you
ninja_freak318@hotmail.com
Nov 15, 2011 | Sony Playstation 3 (PS3) Console
The tv will run pefect for some time 30min to 4 hours , the picture will start jumping and then go into hundreds of lines and colors. Sound still works great. Can unplug for 30 min and will run again...
Your signal board is defective. It is the board with the antenna connection and all the audio video connections. If you open the TV form the back you can get a part number from the board and order it on line. You can find parts at www.interliquidparts.com Be carefull tv's have high voltage make sure it is unplugged for a few hours before you take off the back cover.
Jun 03, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Tv randomly shuts off while watching.
This is normally caused by the Regulator in the Power Supply. You have to measure and monitor the B+ and if you've never done this before I recommend calling a Svc. Co. It;s not a major repair and as long as you feel the picture looks good then you might consider having it repaired.
Mar 29, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Samsung t.v. picture going in and out
it may sound like you have a input or a output problem if you have a video un plug it from the tv. and put your Aral strait to your tv that will tell you if your video is the problem not the tv.
Jan 07, 2008 | Samsung DLP HL-P5663W 56" TV
Olevia lcd tv will not turn on.
First you want to unplug the tv for a few hours to reset settings. Plug it back in and then switch the master power switch off and then on.
There is a master Power Switch next to the power cord receptacle, make sure that this switch is on the on position and the blue LED in the front is illuminated (Note: The switch in the rear of the television is in the on position when the line is depressed).
This should get your tv working again. Just needs a good powercycle.
TECH just worked on a tv I just tried it on.
Dec 02, 2007 | Olevia LT32HVM 32 in. LCD Television
RCA TV D52W136D
unplug your set leave unplug for 30 min plug back up any change?...this reset it.. if still not come up may have other issues
Nov 21, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
