Question about Whirlpool LSR5132PQ Top Load Washer
Washer fills and washes ,stops but will not advance to spin cycle
Tried on other settings and it does the same thing
  • danielviator May 22, 2009
    tried solution 1 before , not that thanks . i'll try solution 2 , i'll let yuo know
    Problem Solver:
  • 4 Answers
Another possiblity is that a sock or other piece of laundry is blocking the pipe to the filter/pump.
When the washer stops is there still water in it? Do you hear any noise coming from the drain pump which might indicate it is working/
Posted on Sep 16, 2009
  • 1,906 Answers
Check your lid switch a pin on the lid should go into a hole on the top or, in some models a magnet is used if the lid switch is not depressed (lid closed) it will not spin (safety device) I insert a pen or, screwdriver into the switch hole to test be carefull though because it may spin with the lid open
Posted on May 22, 2009
  • 975 Answers
If washer will not drain or spin !! , try this solution , 1 ) open washer and at the bottom locate a small DRAIN MOTOR PUMP , is usually clogged with lint & debri , take it out , clean it , replace and try again , let me know , AJ
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Kenmore 70 Series Washer Won't advance in the
    Bad timer. Try to find a used one if possible, this item is a little expensive.
    Aug 23, 2010 | Kenmore Washing Machines
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Kenmore front-load washer stops at rinse cycle
    When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
    Mar 03, 2009 | Kenmore 43142 Front Load Washer
    Frigidaire FTF530F won't advance
    Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
    Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
    Soon as i set cycle and swich on door light flashes open
    hi,
    Thanks for your question.
    Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
    Whirlpool LSR5132PQ Top Load Washer Logo
    224 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
