Question about GE GSS25LGM Side by Side Refrigerator
For no apparent reason, the frezzer side started to accumulate ice all along the back, from top to bottom, and is now a few iches thick
    Problem Solver:
  • 5 Answers
Check the door seal make sure it is making good contact with the frame.
Posted on Jan 04, 2014
  • 1073 Answers
SOURCE: Freezer Frost and Too Warm No Ice
replace the defrost heater wr51x10031
Posted on Apr 10, 2008
  • 7 Answers
SOURCE: frezzer coil water is dripping on it
I'm not sure about your icemaker, but i think it should be fine. Simply put, fridges or freezers have to get hot to make themselves cold, and they do drip water from time to time, although usually not a substantial amount. If you want to learn more wiki fridges freezers etc. the water should be an issue unless there are some exposed electrical wires located near it.
Posted on Jun 09, 2009
SOURCE: Ice accumulation
Solved.
Posted on Jun 25, 2009
  • 308 Answers
SOURCE: GE frig/freezer side by side about 5 yrs
Bad defrost timer, most likely. It is not defrosting the evaporator, and therefore, no air can be passed over it. Hope this helps
Posted on Sep 14, 2009
Testimonial: "Was not helpful. told by parts dept. this frig being five years old does not have a defrost timer.It has a main control board on back of frig."
Sea Breeze
  • 4654 Answers
SOURCE: our ge profile side by side started acting up , it
I believe your motherboard has become defective. If you would like my assistance and instructions on how to fix without a Service Technician visit let me know, Sea Breeze
Posted on Jan 26, 2010
Water accumulates in the freezer tray turning to ice & flows to the floor if ice not removed in time.
there is a drain tube along the back inside of freezer side that clogs up with ice use hot water to melt ,and you may have to remove rear cover in back to remove the drain tube on right side to clear it .
Mar 16, 2015 | Whirlpool GB2FHDXWS Bottom Freezer...
I have samsung fridge side by side ,,,the freezer is messed up not freezing ,,,,fridge is ok
The most common reason for this issue is ice accumulation behind the interior plastic liner which is keeping the air from flowing properly. There are a few ways to fix it, but the easiest is to unplug the appliance, open the doors, and let it thoroughly thaw. This could take a few days. You can also take off the interior panels to get at the ice if you want to hurry the process along, but you can also just wait.
Sop up the water, and when it appears to be done thawing, plug it back in. It'll be just fine.
May 04, 2014 | Samsung RS2630SH Side by Side Refrigerator
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Ice accumulates on the bottom of the frezzer
if frost free freezer then maybe drain tube plugged up with ice.defrost freezer and restart (unplug till ice melts)or drain hose is dirt plugged
Nov 23, 2011 | Samsung RS2630WW Side by Side Refrigerator
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer won't reached desired temp or make ice
Most definately you do. somehow air got in while you were away. 12 hour defrost with doors open will help.(insulation in side by side normally thick).Had one like that approx. 2 months ago but fridge was not well treated and they damaged rubber seal at water and ice dispencer area.
Jun 06, 2010 | Bosch B20CS51SNI Stainless Steel Side by...
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
Back of freezer ices up and the freezer
You most likely have a burnt out defrost heater. The most common part number is WR51X10053, but if you comment back with your exact model number I can confirm that for you. To fix it, you will need to remove the shelves in the freezer so you can take the back wall out. Defrost all the coils by unplugging as you have, or use a hair blower. The defrost heater is along the very bottom of the coils and has a wire connected to each side of it.
Jan 07, 2009 | GE GSL22JFPBS Side by Side Refrigerator
Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
Oct 04, 2008 | Kenmore Refrigerators
Fridge freezing
a defrost problem, is gonna cause excessive ice build up in hte frezzer lower compartment. for somereaon the hdefrost heater was not energized. most common reason is a bad defrost thermostat, clipped on one of hte evaporator coils has gone bad,
Mar 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE GSS25LGM Side by Side Refrigerator Logo
42 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
