Question about Sewing Machines
Husqvarna snowblower does not go forward. The spring is broken on the belt. How can I fix this?
My husq. snow blower when I put in gear it takes off like a rocket ship how do I get to slow down
Posted on Jan 04, 2014
Husquarna 230. The motor belt slipped off,I put a new one on. Now the machine goes backwards when I have it in"Forward" and goes forward when I have it in "Reverse". What can I do to fix it?
[PDF]Manual - Husqvarna Viking
www.husqvarnaviking.com/.../83625f21-a0d3-44fa-884a-fd7db126601...
Read all instructions before using this household sewing machine. DANGER ...Special care is required around the sewing machine needle. ...... DESIGNERâ„¢ Royal Hoop (360x200). 57. ..... you experience problems with the thread, turn it in theopposite way or .... If the upper thread breaks or bobbin thread runs out, the.
Jan 16, 2016 | Sewing Machines
How to fix a broken Needle clamp on viking 936
I don't know of a way to repair the needle clamp. It will more than likely have to be replaced. The local authorized husqvarna viking dealer should be able to service the machine. You can find the nearest dealer from husqvarna viking website - http://www.husqvarnaviking.com/us
Apr 24, 2014 | Husqvarna Huskylock Computerized 936
How do you remove the rose sewing machine case
That's a tricky fix. I recently fixed one (I'm a Service Tech). The spring is wedged into the front cover in the housing. The sewing head has to be removed to access the area. Suggest you take it to an Authorized Viking Dealer to have the work done. You can find the nearest Viking Dealer by going to Viking website - http://www.husqvarnaviking.com/us and clicking on Locate a Dealer
Feb 24, 2014 | Husqvarna Designer I
Machine stops and says thread is broke. Mean while the thread is not broke
Probably one of two issues. There is a sensor in the upper tension that is operated by the check spring assembly. If its broken, twisted or jammed it will sew a few stitches, maybe more and then beep and stop. A service man is the only fix, sorry.
Derek
Nov 30, 2010 | Husqvarna Designer I
We have a Huswana snowblower and the auger does
Sorry, your problem was posted to Sewing Machine category. If you are still having problems, you mnight want to re-submit to another appropriate category for help.
Dec 30, 2009 | Husqvarna Designer I
Sewing machine husqvarna 3610 bobbin case spring has broken and the bobbin will not stay in the machine. How do I repair the spring?
You probably will need to replace the bobbin case. It is probably only available from Husqvarna Viking. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jul 21, 2008 | Husqvarna Viking 1
Broken Cam in a Husqvarna 2000
You can find a video on how to do this at Sewingnz Youtube channel playlist
Jan 28, 2008 | Husqvarna Viking 1
Reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Nov 11, 2007 | Husqvarna Viking 1
Sewing Machines Logo
89 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
