Question about Seiki 32" 720p LCD TV - SC324FB
Need tuner activation code for seiki sc324fb tv
I have a SEIKI SE43FGT LED TV and I've got no sound or picture but Netflix and you tube still works but it also asks to run autoscan
If you are using cable the tv tuner is not utilize as the cable box is the tuner.If you using an antenna then an auto scan will pull in the strong signals.You can do this from your settings menu
Feb 07, 2018 | Seiki Televison & Video
Trying to start tv, screen says run auto scan again. cannot make it do that.
it sounds like you may not have a digital tuner in tv? if not you have to used a external digital tuner to your tv! they make many types, pick one up on line or local Walmart, etc! good luck!
Jun 12, 2017 | Televison & Video
Seiki model SC324FB - no color picture, black & white only
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 08, 2017 | Seiki Televison & Video
One for all universal remote i am trying to program my seiki television. I lost the original remote and the power button on the television is broken so I cant turn the television on
Always better to buy a genuine replacement. The problem is that if I remember correctly, Seiki don't actually make the television, which is why it never features in the Remote Code Lists. I have just checked three sites.
http://codesforuniversalremotes.com/3-digit-universal-remote-codes-for-tv/
http://removeandreplace.com/2013/11/10/universal-remote-control-codes-list/
Brand new original SEIKI seiki TV Remote control work for almost all ...
https://www.amazon.ca/original-SEIKI-Remote-control-almost/dp/B00BJ2MC0E
I gave my mother a sieki television for Christmas my two little girls are always using the remote and letting it drop so I needed to find a replacement remote asap.
SEIKI TV Remote Controls ' SEIKI Replacement Remotes for TV, DVD ...
https://www.replacementremotes.com/SEIKI/Remote-Controls/ ReplacementRemotes.com offers SEIKI remote controls for sale online including remote controls for TV and many more.
Google seiki remote control codes
Jan 09, 2017 | One For All Televison & Video
Seiki tv se40fyp1t can not save any dvb-c channel.I live in SD USA. It shows that tuner is active but on search no digital channels.
check with any store locally that sells TV's you might just be trying to get something that doesn't exist
Jun 03, 2016 | Seiki Televison & Video
My picture keep blinking off and on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Jan 08, 2016 | Seiki 32" 720p LCD TV - SC324FB
Tuner activation of SE32HY10
Try this link to download the user manual to this set. It has all details.
http://www.seiki.com/Manuals/Seiki_Manual_SC32HT04.pdf
Dec 03, 2013 | Televison & Video
TUNER ACTIVATION CODE LD3288M,SERIE:11196212194
I have a problem whith TV, LCD :APEX , model:LD3288M serie:11361580239 ,, i need the tuner activation (ATSC), code for the channel,, please help me, my e-mail : moril_23@yahoo.com
Apr 23, 2013 | Apex Digital LD4088 LCD TV
I have seiki tv i cn not find the chanales
Check and replace its tuner. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Feb 26, 2013 | Seiki 24" LED TV - SE-241FS
Remote code for Seiki TV 32"
The "try the Samsung codes" suggestions works. I have a ONN (Seiki) LE-24G90. The first Samsung code on the HDTV list (1019) did the trick on my Telus CISCO ST6400 remote.
Dec 01, 2010 | Televison & Video
Seiki 32" 720p LCD TV - SC324FB Logo
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
ka4iup
ka4iup
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
