Question about Emerson Audio Players & Recorders
Clock not working
Clock plugged in, does not work, only does a brief flash, cannot read., radio does not play
  • 91 Answers
SOURCE: CD will not play
If the radio operates normally but the CD function if inop, than the laser pick-up is out or another critical component of circuitry is out. Its cheaper to replace with an aftermarket deck, than to repair your broken one.
Posted on Aug 04, 2008
p_murfy
  • 63 Answers
SOURCE: My Radio and clock screen has went blank volume and controls
it sounds like the Multi information display has failed (MID). It is the long display with all the radio controls on it. If you want to find a known good part they are really easy to swap out. Just remove the radio knob and if you look down in there, there is a place to put a T10 (i think maybe bigger or smaller) torx T10 screwdriver.if you turn it while pulling back slightly on the screwdriver it should come right out. It usually is the component that fails but as always you may want to check your fuses.
Posted on May 03, 2009
SOURCE: battery ran down.now radio/clock don't work. flashes Error.can this be reset?
try taking the radio out and looking on the top for the parts number. call Honda and tell them what is going on and they will give you a 4 digit code that will reset the radio. i had the same problem with my 05 civic, did that and it worked for me.
good luck
Posted on May 29, 2009
johnk950
  • 115 Answers
SOURCE: Radio clock,bal,fade etc lights don't work,
Likely blown panel lamp fuse
Posted on Sep 04, 2011
  • 70 Answers
SOURCE: I replaced my ford Radio with another factory radio remaufactured. I plugged in the 2 plugs and the antennas, only the clock works. It will take CDs but won't play them, radio doesnt go to radio,
Modern automotive electronics are keyed to the VIN through the ECU to prevent theft, you must have the radio ID #, and key it into the radio with the number pads on the radio, only the dealership can retrieve the correct code for your vehicle. Probably not what you wanted to hear.
Posted on Sep 08, 2012
Will not work.
Hope it's not an expensive radio. it looks to me defective. It's not easy to get radios repaired currently. Most tiemservice worth more then the radio
Aug 19, 2015 | Audio Players & Recorders
Set time on clock radio CS238-5G
This is the way I worked it out, as soon as you've plugged in the unit, push the MEM button for a couple of seconds then push the PLAY/PAUSE button and hour will start to flash then use the arrow buttons to change hour, then push PLAY to change minutes. Once you've finished minutes push PLAY again. Not sure about setting alarms though and if you get stuck, unplug it and start again.
Mar 26, 2014 | GPX CRCD6306DT Clock Radio
Sep 08, 2012 | 1999 Ford Explorer
The cd player is not reading the discs. The read out flashes and blinks but it does not read the music off the disc.
Try removing the cover and clean glass laser eye lens with rubbing alcohol and cotton swab. If cleaning doesn't work, then laser lens circuit will need to be tested and replaced. You can use an ohmmeter to test the capacitors and circuit.
Nov 13, 2009 | Bose Wave Radio
After many years of use the Radio does not play. CD is o.k.
its very possible and most likly that the antenna receiver unit in clock is worn out, unfortunatly there is no cure for this as you cant buy replacment parts for it
Nov 07, 2009 | Philips AJ3980 Clock Radio
CD player stopped working on Sony ICF-CD831 PSYC Clock Radio/CD P
I've been able to prolong the life on mine by doing this:
Insert the disc, then spin it by hand and quickly close the door and hit play.
It's always worth using a laser cleaner first, as it may just be dirty and stops spinning because it cannot read the disc.
Apr 26, 2009 | Sony PSYC ICF-CD831 Clock Radio
Troublshooting my clock radio CKW2000 Emerson Research All Alert Clock Radio
I don't know if it work for everybody, but, I took out three of the batteries, then unplugged the radio and plugged it back in. That just left the bottom light blinking, I then pressed the power button on and back off. I had to reset time and date, but it got rid of the flashing lights.
Aug 30, 2008 | Emerson CKW2000 Clock Radio
Will not play cd
just received by durabrand under the counter cd/radio plugged it in and all i get is static on both what can i do to fix it
Jan 24, 2008 | Durabrand W375-K Clock Radio
143 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
