Question about BenQ Vad6038 Dvd Drive Motor Spindle Xbox 360
Xbox trouble Not reading games intermittently changed laser still same could it be motor
  • 1,511 Answers
Better off going for a replacement DVD as you may never get the drive motor to function normally. Timing is important and alignment super important.
Posted on Jan 07, 2014
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
XBOX 360 Elite won't play disc; says "reading" then "open tray".
If the console has never been opened to change the dvd drive then eather your laser lens or one of the 2 motors in the drive needs to be changed. 90% of the time its the laser lens. You cant just use any laser for the xbox 360. There are 3 different drives. Toshiba, BenQ, Samsung, so you have to see what drive model you have before you try to order one yourself. I repair these often with 99% success.
Jan 24, 2010 | Microsoft Xbox 360 Elite Console - Black
My xbox won't read my disc. It goes to the My Xbox and it says Open Tray and won't read the disc
If the dvd drive has never been changed then you have eather a bad laser lens or one of the 2 motors have burned out. I repair these problems all the time with 99% success rate.
Jan 23, 2010 | Microsoft Xbox 360 Console
My xbox 360 WONT read ANY of my games, and may be breaking games
This means the laser in the dvd drive has become mis-aligned, the laser will need replacing because if its breaking games the laser its self may be damaged. When one of these comes in for repair I will change the whole drive,its a lot less hassle, there are plenty of how to vids on youtube.
Hope this helps.
Jan 16, 2010 | Microsoft Xbox 360 Console
Xbox 360 not reading discs
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
Nov 17, 2009 | Microsoft Xbox 360 Console
My xbox 360 isn't reading the games
Laser is weak , needs new laser
or one of the two motors in
the drive is dead, needs new drive
If you need to replace the drive
you will have to remove the old drives P.C.B
a instal in the new drive.
Jun 14, 2009 | Microsoft Xbox 360 Console
My Xbox 360 Halo 3 edition hardly reads any disc successfully!
This most likley a weak laser .
8 mw 633 nm laser diodes fail in stages
as they get weaker the cd ups voltage
to the laser diode till you get to full gain, affter that
it's time for a new laser .Good news
there cheap 30.00-40.00 and not too
hard to swap out yourself .
Rob
Jun 13, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
My xbox plays cds/movies but not games. what do i do?
Have you recently tried to flash this xbox??
Anywho, your laser needs changing. Its giving off the signal to your motor and your motor isn't spending fast enough to play a game. Games require a higher RPM to read while movies require a lower RPM.
Your laser and/or motor needs changing. Send it in for repair.
http://www.newcorp.com
May 28, 2009 | Microsoft Xbox 360 Console
I have a problem wiht my xbox when i stick a game or disck it has problems reading the disck i have checked the game and my other games for scraches but the games are fine sometimes the reading time takes...
well...its gotta be your laser if its having trouble reading you need to either find out how to take it appart or call microsoft and see if they can fix it for you i hope it helps...you can find ways to take it apart to clean your laser on youtube...
Mar 17, 2009 | Microsoft Xbox 360 Console
BenQ Vad6038 Dvd Drive Motor Spindle Xbox 360 Logo
49 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
