Tivo stream need a tivo password
Why am i getting a Temporary Service Connection error message?
Did you go into Settings, Phone and Network, Change network settings, and inform the TiVo of the changes, especially to the SSID (which you should not be broadcasting)?
I'm pretty sure the TiVo doesn't need to know the router's password, if you mean the password you have to enter to access your router via a web browser for purposes of changing settings on it, although if you're running any kind of wireless encryption on that router the TiVo will need to know whatever password is associated with that.
And while you're at it, consider giving everything on your home network that doesn't leave the house a fixed IP address that lies outside of your router's DHCP address pool, and making that address pool only a little bit bigger than the number of devices you anticipate needing an IP address assigned via DHCP once you've handed out fixed addresses to everything that doesn't travel.
Jul 13, 2014 | Tivo Series2 TCD649080 Video Recorder
Why am I getting a Temporary Service Connection Error message?
Tivo won't know this until you tell it.... you need to change your network settings on your Tivo to reflect the new SSID and password...........
Jul 13, 2014 | Tivo Series 2 80-Hours Video Recorder
I AM CONNECTED TO FIOS VERIZON. MEDIUM HIGH SPEED. IS THERE A WAY TO GET NETFLIX HOOKUP THRU THE WIRELESS ROUTER I HAVE FROM VERIZON to my tv..
There are multiple ways to stream Netflix over a high speed internet connection. You will need a device to run the Netflix streaming - your choices are Playstation3, Wii, Xbox, Tivo Premiere, or a Roku box. You could potentially use a computer connected to your TV to stream it as well, but the computer would need the appropriate outputs to hook up to your TV.
Mar 15, 2011 | Mitsubishi WD-60737 60 in. HDTV
We have lost the original disc that came with the TIVO and I need to get the Tivo wireless network adaptor set up on our wireless network. How can I do that without the disc, is thee anyway around that ?
The disk us usually not necessary. If you are using a series 2 TiVo you just plug this in to the back of the TiVo and it will recognize it. In the TiVo menu find Network Settings. If you select change network settings it will ask you to select your wireless router and ask for the password to your router if you are using one.
Dec 31, 2010 | Tivo Wireless-G USB Network Adapter
I have a problem with tivo it says my gateway canot be found is this a router problem or a setting.its happened overnight.im getting 87 % signal strenth
I would check the router to see if something has changed.
Sometimes you need to re-add the wireless password to the Tivo Setup.
Jan 05, 2010 | Tivo Series2 Digital Video Recorder...
My tivo HD is not broadcasting or recording in HD
As far as I know, you need the cable cards to get HD through the Tivo, because they're what does the HD decoding and output.
Jan 18, 2009 | Tivo HD
Can't get benefits of service because I lease TIVO thru cable co.
Your cable company is telling you that you do not have enought band width to download and use (VOD) Video On Demand.  They are unwilling to sell you, or your equiptment does not support such a high speed continuous download.  No.. Their is no way around it. Nextflix or Redbox may be alternitives for you.
Dec 26, 2008 | Dell OptiPlex GX270 PC Desktop
Televison & Video Logo
Top Televison & Video Experts
