Question about Zebra Office Equipment & Supplies
Zebra printer not printing multiple copies - Zebra Office Equipment & Supplies
  • 158 Answers
SOURCE: Can't print multiple copies
On your Brother's drop- down menu, left click on PRINTING PREFERENCES . On the BASIC tab, choose the number of prints in the COPIES box, then left click on APPLY. If that does not work, go into PROPERTIES, left click on the SECURITY tab, and check that you have authorization to run multiple prints. Also, check your PRINT SPOOLING mode to make sure it is activated, and check authorizations in OFFICE 2007- it may be set to restrict multiple color pints.
Posted on Aug 31, 2008
freetek
  • 5568 Answers
SOURCE: My hp 1320 prints only one copy
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system. This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
Posted on Sep 23, 2008
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
SOURCE: unable to store job at printer, printer not configured to collate
Problem -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
Error “Unable to store Job at Printer”
Reason “Printer not configured to collate”
Solution “Install an EIO hard disk”
Usually when trying to print a multi page document.
Solution 1. Start > Control Panel > Printers
2. Locate the printer > Right Click > Properties.
3. Device Settings > Mopier Mode > Set to Disabled.
4. Apply OK
Posted on Mar 21, 2009
SOURCE: My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Posted on Mar 01, 2010
When I try to print multiple cards, only 2 cards print, the same two all the time, the others don't
It sounds like you might have a job stuck in the print-queue. Best way to check is to start with a clean slate:
1. Shut-down your badge-software, and disconnect the printer from its power source;
2. Navigate to the Windows print center - accessible from the Control Panel as "Printers & Faxes" if Windows-XP, or "Devices and Printers" if Windows 7.
3. Right-click on your Zebra P110i printer, and select "See What's Printing" to open the queue, and see if there are jobs there. If so, click "Printer" on the menu, and then "Cancel all Document".
4. You also should ensure that you don't have any additional instances of the printer drive installed - they would show up as Zebra P110i (Copy 1), ... (Copy 2), etc. This occurs within Windows if you've disconnected the PC-end of the USB cord, and then plugged into a different USB port than originally used. If you have multiple instances, the easiest way to clean this up is to right-click on each sequentially, selecting "Remove this Device". Do this for each one.
5. Now you have a "clean slate". Connect the Zebra printer to the PC's USB, and then re-connect the power. If it doesn't power on, push the power button so it is on.
6. WAIT until Windows recognizes the pritner and you see the device is ready to use.
7. Open your badge software, and select a single card to print, and send it to the printer. If all goes well, this single card will print correctly, then the printer will come back to a ready status. Repeat for a second card, and make sure it prints correctly, and comes back to ready. If all is good, you've likely cleared the issues up, and you can proceed normally. If not, then there may be a physical problem with the printer, where it is not recognizing that a finished card has been ejected and the job is done, or it's not communicating that "done" status back to the host PC.
Feb 07, 2015 | Zebra P110i ID Card Printer
My zebra tlp 2844 not print multiple copies even if I specify the number of copies in the setting of the printer
Do a hard reset on the printer. Completely remove the printer software/driver and reinstall from a new source (manufacturer website)
Mar 09, 2014 | Zebra TLP 2844 Thermal Label Printer
Zebra printer is printing two copies when only 1 is checked
Same problem exactly and was not able to get a response from UPS or the zebra company, someone please help!!!!!!!!!
Mar 19, 2010 | Zebra LP 2844 Thermal Printer
Cannot print multiple copies
Is the printer set for label taken, if it is then it is waiting for the sensor to see the label is gone before printing the next one. Apart from that, check the settings in the driver and make sure it is all set correctly
Feb 09, 2010 | Zebra Z4Mplus Label Printer
Zebra S300 printer pauses without printing additional copies
I Use driver from Nice Labels
http://www.nicelabel.com/downloads/nicedrivers/zebra seems to work fine
Dec 05, 2008 | Zebra Stripe S300 Thermal Label Printer
MY ZEBRA TLP2844 print a symbol...
de-install then re-install the printer driver.
also if it has multiple interfaces (such as serial and parallel) be sure to load the appropriate driver.
Nov 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Sep 24, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
