Question about Whirlpool Dryers
Dryer won't go past sensing and dry
Model GEW9868..has console at top that shows what it's doing..will run and never goes onto dry...just sets at sensing, so won't get hot or dry.
  • 6,784 Answers
HI. you will need to replace two devices here. the thermistor assembly and the Moisture sensor bar. these two components are faulty and, replacing these components will correct this issue.
Posted on May 22, 2009
Gas dryer does not dry in "timed Dry" setting
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
AUTOMATIC HEAT SETTINGS NOT WORKING PROPERLY
lg's have a dry sensor that senses the wetness of the load they are not that reliable.. and will shut down the machine does it work on manual timer? meaning set it on high for 30 minutes.. it will probably run the 30 minutes... I have had this issue with my lg and so I just use the manual settings cheaper than having a 300$ service call. Its a problem with the dry sensor on the lining of the drum...
Dec 09, 2013 | LG DLE5977 Electric Dryer
Whirl pool duet dryer not drying clothes
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
I have a Kenmore 500 series dryer, model number 110.79522800 that will note completely dry clothes. It seems like it doesn't run long enough, heat high enough or a combination of both. What can I do to...
Your Sensor that senses the clothes are wet or dry is shorted out. The dryer works likes this so the dryer heaters dont stay on while the clothes are dry. When the sensor senses the clothes are damp or wet, the heater stays on, when they start drying the sensor senses it and starts to turn down the heaters
http://tlc.howstuffworks.com/home/dryer6.htm
Mar 10, 2011 | Dryers
Need the manual to understand operation, problems with drying
84052/94052 is the stock number and 417.94052500 is the actual model number
How long did you let it run on sensor? Some models may need to sense for a while before they decide to start heating.
The knob can be turned either way
Manual: http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0502104.pdf
Sep 02, 2009 | Kenmore Dryers
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryers Logo
270 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
