Hp laserjet 1536dnf mfp. Feeder won't feed. How do we fix that?
Feeder won't feed, have to use glass for everything. Tried cleaning...any fixes?
4 Suggested Answers
atsonev
  • 39 Answers
SOURCE: My HP Laserjet 1536dnf MFP
10.0000 Supply Memory Error - A specific print cartridge has an e-label error.
Solution:
1.Reinstall the print cartridge.
2. Turn off and then turn on the product.
3. If the problem is not solved, replace the cartridge.
Hope this helps
Posted on Sep 13, 2011
  • 313 Answers
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
walid_sayed@hotmail.com
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Posted on May 07, 2010
SOURCE: SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Posted on Feb 04, 2011
ERROR MESSAGES ON HP LASER JET 1536DNF MFP jam in cartridge - there is no jam
Check to see if the paper is feeding, should be feed some what into machine, if not paper is not getting to cartridge and showing a jam... some times clean wheels with water or windex
Mar 28, 2017 | HP Office Equipment & Supplies
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
Copying function produces lines on paper
If you put the page to be copied on the glass and it prints ok, but when you put it through the feeder you get lines down the page, then the small glass has ink or other dirt on it and needs cleaned. e971cea9-3ef4-4b05-af43-2f365de08d96.gif
Mar 12, 2014 | HP LaserJet Pro 400 color MFP 475dw
Scan streaks with HP LaserJet Pro 200 color MFP M276nw
This may not always be the solution, but in my case it was. If you are getting black streaks on your copies, try this first:
The problem is that that there a small piece of glass that the doc feeder use's to scan the original. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out or other residue, on the glass, just clean with a monitor wipe or take a cloth & wipe, etc...... Good Luck
Online tip from Chris Coughlin, but I changed a few of his words.
Feb 05, 2013 | HP LaserJet Pro 200 color
Line down page when using the paper feeder to scan... prints fine directly from the glass
Hi there, Open up the flatbed. You will see to the left side of the glass a small strip of glass.That is the glass the Document Feeder uses when scanning. Just clean it properly because a lot of the times people use tipex or some sort of correction fluid or even wet ink and it gets stuck on the glass creating lines then.
Regards,
Jul 29, 2011 | HP LaserJet M3035xs MFP All-In-One Printer
HOW TO CLEAN THE HP LASERJET M2727NF
To clean the Top Feeder rollers simply buy/get a can of WD-40 and clean both rubber rollers, also clean the smaller glass with alcohol if you get lines on your copies using the feeder and not the bigger glass platen. Take each drawer out and find the feed rollers, you should be able to clean those with WD-40 as well.
Mar 31, 2010 | HP M2727NF Laserjet Printer
I have a HP LaserJet 3330 copier/printer.When I use the document feeder on top I get a black line. When I put it on the glass, no black line. Help!
You may have some thing like a small piece of paper or some other obstruction in your document feeder mechanism that is blocking the light to the document or ostructing the view to the image sensor. Carefully clean that feeder and rolls perhaps by blowing.
Jan 18, 2010 | HP LaserJet 3330 All-In-One Printer
I have a m3027 mfp hp printer top feed won't grab
turn the power off.remove ink cartridge then check there is not any paper jam.aslo check in back side of printer for paper jam .also clean your ink cartridge try other ink cartridge.
Jan 05, 2009 | HP LaserJet M3027 MFP Printer
214 people viewed this question
k24674
jasbo
jasbo
