Question about Kitchen Appliances - Others
Scotsman ice machine problems
Scotsman MV450 ices up & switches off. seems to be using lots of water. water level drops drastically
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Harvest thermo must not be working, or harvest cycle motor
Posted on Apr 07, 2014
4 Suggested Answers
SOURCE: Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
Posted on Nov 07, 2007
22yooper
  • 828 Answers
SOURCE: hello mate re mv450
Check the ice thickness sensor for mineral buildup and clean if necessary. I downloaded the service manual from a site in New Zealand. If the Ice thickness sensor is free of scale make sure you are NOT supplying the machine with soft water.
Let me know if this solves your problem. I have been servicing Scotsman Ice Machines for over 38 years in the US. I will try to assist you any way I can. This particular model is not sold in my country.
Posted on Jun 03, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
Check the dump valve if water is seeping through the dump valve then the water inlet valve will be adding water to sump all the time to replace water lost. Now if water is running over sump into ice bin then look at water inlet valve.
Jul 17, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman cm3 does not harvest
your sump level control sensor is not reading the water level drop to go in harvest.you can do a self check test or replace the sensor(little blk box) could be wire harness. check to makeure your water value is leaking through
Feb 11, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman cme256 as-1d sticks in harvest cycle
The only thing that tells the machine that a harvest cycle has completed and takes it back into a freeze mode is the ice level control. when the machine go's into a harvest the ice drops through the ice level control and brakes the beam and switches the machine back to freeze cycle. Pull the the ice level controls and replace them. if there is nothing wrong with them than it is the electronic controller. part number for ice level controllers are 11-0540-21. The part number for the control board is 12-2838-24
Dec 07, 2013 | Scotsman Kitchen Appliances - Others
I have a MV450 icemachine that work for up to 4 days without any problem .Then it cuts out the hi pressure indicator light up .i have checked the gas charge and cleaned the condensor
The magnetic switch just lets the machine know it finished a harvest and start ice production all over again. high pressure could be a dirty coil, fan motor stops working, a possible refrigerant restriction, or the room that the machine is in is getting to hot but this would cause the production of ice to take longer. it should be making ice every 15 to 18 mints in a 74 deg room.
Oct 05, 2013 | Scotsman Cooled Modular Contour Cuber Air...
MV450 Scotsman Ice machine
1. bin full when bin is empty means that the bin control sensor is dirty or need to be replaced. But since your having problems with water over flowing also i would bet that your machine needs a good cleaning. is you water full light on or off? if off and water sump try is full then you need to pull water sensor out and clean or replace it. if water sensor light is on then you need to replace water inlet valve.
Jun 26, 2013 | Kitchen Appliances - Others
I have some problem with our machine scotsman mv450 is to long product ice very slowly
Min freeze time 6 minutes and max freeze time 45 minutes. the 6 minutes is with perfect conditions. Example: Cycle time water temp was 50 degrees coming in to the water sump tray from water supply and the Ambient air temp surrounding the machine was a constant 70 deg than the machine should make ice every 10 - 12 minutes.now we know that the water temp from the water source is not going to be 50 deg and room temp will not be 70 deg all the time so the warmer water temp and ambient air temp is the longer it takes to make ice. one thing you wont to check is the water inlet valve to make sure it is not letting water seep through causing water temp not to cool down from running across evap plates. make sure the condenser coil is clean this will slow down production of ice.
Apr 17, 2013 | Kitchen Appliances - Others
Mv450 scotsman high pressure
Check to make sure the condenser coil is clean, fan motor is running during freeze cycle. High Ambient temp, Ventilation, The higher the temperature entering the condenser coil the higher the head pressure. Fan motor failure, pressure switch failure. The cut out pressure varies 400, 450 or 500 PSIG. Water supply failure. not enough water running over the evaporator plate will cause high presser.
Jul 30, 2012 | Scotsman Cooled Modular Contour Cuber Air...
MV450 SCOTTSMAN ICE MACHINE
Personally I think the prices that you paid for the new TXV and dryer are VERY far out of line.Get what information you can off of the TXV power assembly and valve body along with the manufacturer of the valve and I will see what I can find out for you. If it is the power assembly that is rusted out and leaking there are kits for replacement parts on most valves.
Oct 23, 2008 | Scotsman Cooled Modular Contour Cuber Air...
Hello mate re mv450
Jun 03, 2008 | Scotsman Cooled Modular Contour Cuber Air...
Kitchen Appliances - Others Logo
123 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
