Question about Superior Lennox Blower Thermal Sensor - BTS
Lennox g8 blower motor wiring
Motor wiring diagram to install replacement motor
Replacing motor on my ruud furance
you should have a wiring diagram on the top of the motor to tell you what each wire does. compare both motors and see where the wiring goes.
Nov 08, 2014 | Heating & Cooling
Motor needs replacement
Most manufacturers have all that information on their websites. Try visiting Bissell's website and in the search bar, type in "motor wiring diagram".
Apr 20, 2014 | Bissell 4104 Bagless Upright Cyclonic...
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
Blower will not come on
Sort of...it the control that allow the blower motor to run at different speeds. Check for voltage at the wires going into the motor...I assume you checked before replacing the motor, but check again. If voltage is there, a bad motor was installed. If no voltage, consult a Haynes Manual wiring diagram to trace the wires from the blower motor back to the source (batt). Best of luck resolving this issue.
Nov 25, 2013 | 2008 Mitsubishi Lancer GTS CVT Sedan
Looking for westinghouse wiring diagram for blower motor model number 319p798
I have just removed one of these motors today. The cabinet has the wiring diagram on it. I will be back on site once I find a replacement motor and can get the diagram then.
Any idea what motor replaces this one?
Dec 20, 2010 | Heating & Cooling
Need a wiring diagram for a maytag gas dryer dg312
If the old motor is still installed simply change wire for wire.
Jul 27, 2009 | Dryers
AC condensor fan motor replacement
one wire goes to the coil one to the capacitor and one line
Jun 20, 2009 | Carrier 38CKC036 Air Conditioner
A diagram of how to install a heater fan in a 1992 pickup
well its an easy replacment unhook the power and ground wires on the motor remove the bolts and remove the motor install the new one
Jan 11, 2009 | 1991 Chevrolet K1500
Computers & Internet Logo
82 people viewed this question
Top Superior Computers & Internet Experts
David Payne
David Payne
Are you a Superior Computer and Internet Expert? Answer questions, earn points and help others
