Toshiba Satellite screen has a "dark shadow" on the right side.
The laptop/tablet is working fine and perfectly. It's just that one side of the screen looks like the brightness isn't working and it's just darker than the rest.
    Top Expert:
  • Computers & ... Master
  • 22,158 Answers
That could be a backlight or GPU issue. Plug an external screen into the vga out to check the GPU.
Posted on Jan 04, 2014
Paeroa
  • 457 Answers
SOURCE: Problem LG XNOTE 229QA2
Please try and external monitor if the picture is OK then you are having LCD problems. I dont know for you but over in the States here: http://lcdrepair.net They maybe, are able to help you.
Posted on Sep 29, 2007
geminii_lady
  • 87 Answers
SOURCE: Toshiba screen goes blank when it is opened too far
Sounds like a problem with the ribbon for the screen being either having a loose connection or getting nipped. Pretty common on laptops because the ribbon runs along by the hinges on the base and then up to the screen.
Hopefully you will be able to access the ribbon on your model by removing the plastic bezel which lies just above the keyboard. The ribbons I have seen are about 1/2 inch wide and as I said connect on the base and the screen. The connection just pushes in. If its loose at the connection on the base then obviously push the connection fully home. If it's getting nipped then reseat it so that it does not get caught. ***NOTE*** a problem could arise if the ribbon has actually been damaged from being nipped - opening the laptop could cause it more damage and then you could lose the screen until you replace with a new ribbon. These can normally be purchased on places like Ebay and don't cost an arm and a leg.
If this helps, I'd appreciate feedback so other people can use this as a solution. Thanks
Posted on Nov 22, 2008
ghost_cyrix
  • 33 Answers
SOURCE: Screen Brightness gone too low on toshiba satellite 1110 laptop
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
Posted on Dec 01, 2008
  • 60 Answers
SOURCE: toshiba tecra m4 tablet pc screen problems
Video driver update try updating your video driver
Posted on Jun 16, 2009
CYCLMTR
  • 30 Answers
SOURCE: Dark shadow on left side of laptop screen
THE SCALAR OF YOUR LCD ARE LEAK IT'S RECOMEND TO REPLACE A NEW ONE LCD
Posted on Aug 18, 2009
Risht side of display turns down resolution
check the display on some monitor through the vga port of the laptop whether the same is happening there, if its there then problem is of display driver, remove the driver boot the system then install it again, check it
Feb 03, 2013 | Toshiba Satellite L645-s4102 Notebook
Toshiba A105 - S4334 laptop,imediately on startup the screen goes so dark I can't see anything but a shadow of the screen,if I clsoe lid and open again I can see the display but only for a few seconds.Is...
Hello wall flower hi, when you turn on the laptop, did you see the start up screen clearly? can you read words on the screen, and then it goes dark? If this is the case, check first the Fn key with the corresponding display for projector, (usually Fn+F5) this combination key is used to display the content of your computer to the LCD or Projector, IF not such a case, it may be problems with your laptop inverter board that powers the backlight. Check your bios settings also.
Feb 12, 2010 | Toshiba Satellite A105-S4334 Notebook
Toshiba Satellite a45-s130 screen has gone real dark need a flash
Paul, Georgiana and You, 1. do you have an antivirus installed on your laptop? if not, then install one rightaway. 2. also from start->control panel->system->hardware->display adapters and monitor. uninstall the display adapters and reinstall them. similarly uninstall and reinstall the monitor drivers. 3. go to http://www.drivershq.com/Drivers/Toshiba/Satellite/A45-S130/4183/9941/10606/Drivers.aspx you will find here a driver detective that can detect your driver problems. try with that. 4. on the site above you will find drivers, for you to download and install on your laptop. if you still have problems, then you have
Sep 02, 2009 | Toshiba Satellite A45-S130 Notebook
Toshiba tecra m4 tablet pc screen problems
Jun 16, 2009 | Toshiba Tecra M4 Notebook
Lcd monitor dark
You probably need to set contrast, etc, using Fn and an other key (F1 - F12).
Mar 27, 2009 | Toshiba Satellite A135-S2276 Notebook
LCD starts to display for about 2 seconds then goes dark.
lamp(s) perhaps.... with an LCD monitor (the desktop kind) you can shine a lite behind it. if you can see things on the screen it's the lamps... if you can't it's something else.
Robert
Aug 28, 2008 | Toshiba Satellite 1135-S125 Notebook
Toshiba Laptop Dark screen-cant really see it!! help!!
sounds like your inverter is gone. The inverter supplies voltage to the backlights of your lcd.
Mar 25, 2008 | Toshiba Satellite A70 Notebook
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Computers & Internet Logo
David Payne
David Payne
