Question about Polycom SpectraLink 6300 MCU
Reset password admin - Polycom SpectraLink 6300 MCU
How to reset admin password with the cmd when you are a standard user
What's your operating system? After logging in as standard user, you have insufficient privileges to change the admin password via cmd. You need to boot with Windows install media, and replace sethc.exe with cmd.exe. When rebooting to the login screen, you can launch a command prompt and reset your password there.
http://www.top-password.com/knowledge/reset-windows-7-password-without-reset-disk.html
Dec 20, 2016 | Computers & Internet
Reset Windows 7 admin password is not hard in fact, as long as you follow these methods to do.
Method 1: To Reset Admin Password with Administrator Account
On Win 7 logon screen, click user and "Switch user" to choose another administrator to sign into. Turn to Control Panel and navigate to User menu. Choose the account you want to reset its password, and remove its password. And then set a new password for it.
Method 2: Reset Admin Password with Password Reset Disk
You have two ways to get password reset disk. One is create it when you still have the administrator password. The other is to create it with third-party software, such as Windows 7 password genius.
Similarly, on Win 7 logon screen, after type wrong password, click link "Reset Password" to go on. Or insert password reset disk into Windows 7 computer and boot it from disk. Windows 7 Password Genius runs, at the same time, all accounts and password list for you. Choose the administrator account, and click "Reset Password" to finish Windows 7 admin password reset.
May 29, 2013 | Samsung SRD-440-500
How to reset the admin password for dell 5330dn printer
Umm, you can reset admin password for Dell with Windows Password Recovery Tool. Only 3 minutes, you can reset it successfully. Not need to reinstall system.
For more detail guide on how to hack a laptop password Dell, please read this article:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
Here is Video guide:
Aug 10, 2011 | Dell Office Equipment & Supplies
How to unlock the password
On the back it has a reset button (you may press it with a paperclip). Check the manual for how long you have to keep pressing it restore factory defaults and what will these be exactly (usually admin/password or no password at all).
Mar 01, 2011 | Computers & Internet
How do I log into my router config if I don't know the password? I've tried pushing the button on the back to reset but that didn't work
Hi vmontour,
To Factory reset your router you need to locate the Reset Button at the back of the router. The Reset Button is the small hole at the back and you need a Pen or a Paperclip to press it. Press and hold the reset button for 15-30 seconds. Make sure that the router is on when you reset it.
To access the router page just open a browser then type 192.168.0.1. the username is admin and the password is blank.
Rate me if this will help you so that i can help other people.
Thanks for using Fixya.
Jan 31, 2011 | D-Link AirPlus DI-524 Wireless Router
Lost my key password for belkin g router
there is a small reset button that u will need to push with a pen. Its usually to the back or side of the router.
Just jeep pushing it until the router resets then use the default username and password.
defaults. (normally)
user name - admin
password - admin
username - Admin
password - admin
username Admin
password Admin
user name Admin
password (blank)
username admin
password blank
look in your manual for the default username and password and instructions on how to reset.
Feb 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
Polycom SpectraLink 6300 MCU Logo
52 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
Sandeep Kamat
Sandeep Kamat
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
