Question about 2009-2012 Ford F150 Lariat/King Ranch Main Upper Black Aluminum Billet Grille : F66788H
The stereo no longer automatically adjusts the volume when the reverse sensor system is activated while backing up
Car stereo just randomly stop work doesnt allow me to turn up volume or change stations or set it to aux none of the buttons work but the stereos turns on.. what could it be???
Well knowing what stereo you have would help, but mine, the volume knob doubles as the settings knob if you press it. In some newer systems like mine, you should find a "back" button (small arrow) like on a cell phone. Trying using that to escape the settings mode that you might have activated.
May 28, 2014 | Car Audio & Video
Replace tv video card
FOLLOW this steps and fix it. God bless you
Perform some basic troubleshooting steps that apply to all TVs. These include checking the "Mute" button to see if it has been pressed, examining the L/R balance to ensure sound is coming from both speakers and checking the cable connections to auxiliary components such as the stereo system (which controls external speakers).
    • 2
Double-check the audio output jacks if you are using an S-video connection (a single round perforated jack) or component video connection (a trio of green, blue and red jacks). Those jacks only run the video signal to the RCA TV. In order to get an audio signal, you'll need to connect red and white RCA cables to their respective jacks on the TV.
    3 Check the back of the TV for a switch labeled "Int/Ext." It controls the sound input on some RCA TVs. If you don't have any separate speakers, the switch should be set to "Int."
      • 4
    Activate the sound set-up feature by pushing the "Menu" button and scrolling to the sound bar. (This option can usually be found only on RCA flat-screen and projection screen TVs.) The sound bar allows you to set the sound from mono to stereo, activate the surround sound features, adjust the sound for headphone use, set volume levels and activate preset sound levels for movies, sports, concerts, video games and other specific sorts of programming. If any of these settings don't match the configuration of your home theater system, it may cause problems with the sound. If you're confused about the options, select any settings that read "Normal" or "Automatic." That should set the RCA TV to factory standard audio settings.
      • 5
    Press the "Menu" button and scroll to the "Set-Up" option, then go to "Preferences." You'll see a bar on the menu marked "Maximum Volume." You can use that to limit how loud the TV can get, which can cause problems if you don't know it's been set. Move the arrow on the bar to reset the maximum volume, then hold down the "OK" button on the remote to hear what that volume sounds like. You can then listen to the TV as normal.
    Jul 20, 2013 | Sylvania Televison & Video
    Hey guyz...my left side speaker getting some noise's when listening to the music,what is the back up of my battery,bluetooth is not working properlly,back up is not working,
    Proceed to the adjustment of volume, audio,& speaker, in make sure that it is set to automatic.
    Check the driver of your bluetooth, if it is install, Then activate the settings.
    Activate your back-up, and check the contents, If it is full in the properties, reformat back-up. If more space in back-up available, may be its only in the adjustment to the settings of back-up.
    Jun 03, 2011 | Computers & Internet
    How do i connect an ipod to my sony str-de310 receiver
    Connecting to a home stereo
    1. For most home stereo systems, connect iPod to your amplifier's sound input using a 3.5 mm mini stereo to RCA adapter cable.
    2. Adjust the volume on iPod to less than half to prevent overdriving your amplifier. Adjust the listening volume using your stereo's controls.
      Note: Depending on your stereo, iPod may need to be set higher than half in order to get a proper volume through external speakers.
    http://support.apple.com/kb/ht2167
    I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
    Mar 12, 2011 | Sony STR-DE310
    I have no volume on certain channels
    The most common problem with no volume only on certain channels is the TV is programmed for 2nd Audio, also referred to as SAP which is a feature activated to transmit a second language such as Spanish. If you push your menu button on your remote control you can toggle over to Audio Menu. Then find the feature that allows you to adjust the sound for Mono, Stereo or 2nd Audio (SAP). Adjust the menu to highlight Stereo and that should cure your problem.
    Hope this helps with your particular problem.
    Dec 05, 2010 | Philips Magnavox 42MF521D/37 Television
    Pioneer vsx 1020 K receiver. I connected the bose 901 eq to the tape in and tape out but it doesn.t seem to be compatible.
    It would be compatible if you ONLY listened to stereo ANALOG sources on ONLY Bose 901's. Engaging any device in a tape loop automatically disconnects digital sources. Bose Active EQ is not intended for anything BUT Bose 901's. The sub could be destroyed by it.
    Lacking appropriate Front Left and Right volume-controllable pre-outs on the 1020k, you can't use the 901's for multichannel or digital source material unless you accept a severe compromise and get a separate amp for the 901's borrow mixed-down stereo from the Pioneer's Tape Out, run it through the Active EQ to the new amp and manually manage the external amp's volume.
    You need Front Pre-outs.
    Jul 20, 2010 | Bose 901 VI Main / Stereo Speaker
    Does not ring
    The Volume key allows you to adjust the volume level for the currently active audio device (handset, headset, or speaker). When no audio devices are active, pressing the Volume key adjusts the ringer volume.
    Adjusting the Volume of the Ringer, Handset, Headset or Speaker
    Note: By performing this function, default volume level will be replaced.
    1. Press the up or down arrow at either end of the Volume key to reach the desired volume level.
    2. When you are satisfied with the setting, press the Save softkey.
    Note: When adjusting only the ringer volume, there is no need to press Save. The settings are automatically saved upon adjustment.
    See the below link for user manual
    http://noc.unet.maine.edu/IPT/7961_7941_User_Guide.pdf
    Jun 20, 2009 | Cisco 7941G IP Phone
    MCM Philips Mcm298/37 Wall Mountable System - volume on timer
    im looking for the same unit to buy, do u know whrere i can purchase one used or new
    May 22, 2009 | MCM Philips Mcm298/37 Wall Mountable...
    How can we turn off the automatic start of Radio or CD setting?
    The activating and deactivating of the 24 hour timer is via a toggle button, labeled "TIMER" on towards the right side of the top console. When the TIMER is activated, you will see a small clock symbol on the LCD display. While the unit is on, tap the TIMER button once. The clock symbol will disappear and the timer is now off.
    Reactivating the timer is the same process (remember, the button is a toggle). Tap the TIMER button and you'll see the timer settings show up on the display (time on, time off, source, and volume). The little clock symbol appears again.
    If you have lost your manual, you can download another one for free from this location:
    http://www.retrevo.com/s/JVC+SD1000
    Nov 17, 2008 | JVC FS-SD1000 CD Shelf System
    2009-2012 Ford F150 Lariat/King Ranch Main Upper Black Aluminum Billet Grille : F66788H Logo
    11 people viewed this question
    Top APS Vehicle Parts & Accessories Experts
    David Harrelson
    David Harrelson
     Brian Main
    Brian Main
    SriPhi
    Are you an APS Vehicle Part and Accessory Expert? Answer questions, earn points and help others
