Oce colorwave 600 error code 15710
How can i SOLVE IT? WHAT THE ERROR REASON? does it need to chaneg a part?
Oce colorwave 500 - error code 4706 (/printer)
The error is Unexpected Nozzle Outs. Ensure that the print surface is clean and you change out your waste toner tray every time you replace a toner pearl cartridge. Sometimes these errors go away with heavy ink usage. Ensure that the paper roll ends are not damaged. That won't fix your issue, but if the rolls are damaged they don't sit flat on the print surface and then the semi dry ink will scrape across the Imaging Devices and add to the problem. Go into the Configuration menu and turn on Enhanced Cleaning. If this doesn't fix the problem in a week, then I would recommend calling an authorized Oce technician. A warning...the Imaging Devices are extremely pricey and you have 8 of them in this machine. Two of each colour. CMYK.
Sep 27, 2017 | OCE Office Equipment & Supplies
Hi i have a problem with oce plan printer 500 it gives me error code 03504 please help me what i need to do
Oce (Canon) makes 3 different types of "500" plan printers. The ColorWave 500, the PlotWave 500 and the old TCS 500. If you mention the proper model number you might get a faster answer. If you have the TCS500 this is a head calibration error. Was a printhead recently replaced? If so it is more that likely that either the plastic seal was not completely removed from the new printhead, or there may be some ink on the contacts on the inside of the printhead socket. Reinsert the printhead in question, and see if this solves the error. Power down the printer and unplug it from the wall. Clean the inside of the printhead socket with a long swab and some isopropyl alcohol. Plug in and power on the printer after replacing all printheads. On extremely rare occasions brand new printhead do fail, so if you have determined you might have a faulty printhead, replace it with another.
Feb 08, 2017 | OCE Office Equipment & Supplies
Oce 500 plan printer error code 03504
Colorwave 650 error codes, 450022,22551,22545
450022 Imaging Device defect
22551 Unexpected unit connection lost
22545 Unexpected inter unit communication lost.
Jun 03, 2014 | OCE Office Equipment & Supplies
Error code on oce colorwave 650
It is a printhead or "imaging device" issue. Call your authorized Oce/Canon service representative. These printheads are proprietary and not available outside of official channels. If you find one outside of official channels be wary of the quality. If there is a a color in in the tube of where the toner pearl goes in, it is a used head and can not be used in any other color except the one that it was originally intended.
Apr 12, 2014 | OCE Office Equipment & Supplies
This is a no toner detected error inside the print head or "Imaging Device". Sometimes a toner pearl misses its mark and bounces out of the tube, although this is rare. If you reboot the system after the printer has cooled down, see if the problem returns. If it does, there could be a problem with the toner dispenser or a problem with the print head itself.
Oce tds 600 error code 08005
you can see you'r answer here:
http://www.copytechnet.com/forums/other-copier-brands/90112-oce-tds-600-08005-error-code.html
Sep 01, 2013 | Office Equipment & Supplies
Colorwave 650. What are error codes 450011 and 450013?
These errors indicate registry errors or system files corruption. It could be due to virus or spywares leading to system file/registry corruption.
Nov 15, 2012 | OCE Office Equipment & Supplies
116 people viewed this question
k24674
jasbo
jasbo
