Question about Heil Sound Audio Players & Recorders
Heil icm plug wiring diagram
Need diagram
    Novelist:
    Scholar:
  • 114 Answers
The Heil "ICM" microphone is designed to be used with certain Icom brand ham radios. These have a 8-pin round plug. Describing the pinout to you will depend upon your perspective, whether you are looking at it from the microphone plug itself, or the microphone socket on the front of the radio. Therefore, from the perspective of looking at the mic plug on the end of the mic cable, note that there is a notch or dimple in the plug that also lines up with the screw. Going clockwise from the notch, the pins are numbered 1 thru 7. Pin #8 is the center pin.
Pin 1 = mic input
Pin 5 = Push-to-talk (PTT)
Pin 6 = PTT ground
Pin 7= Mic ground
From the standpoint of an Icom transceiver, the remainder of the mic connector pins are as follows:
pin 2 = +8 volts DC (output from the radio)
pin 3 = frequency control up/down
pin 4 = squelch switch
pin 8 = audio output (level varies w/vol control)
Hope this helps
Posted on Nov 26, 2014
Heil wiring diagram N8MPN075B12A1 Here can I get a wiring diagram for this unit??
I would go straight to the mfg website and do a search there
or put the model in a search engine and add the words wiring diagram
Oct 11, 2013 | Heating & Cooling
Hi, i have a heil talk box. plugged it to a amp head and i think it was to loud. the bulb burnt so i went to a car shop and got one tht fit(not sure if i needed a certain one or not) anyways, now it wont...
Your amp for this should be no more than a 50 watt amp AND have another 8 ohm cabinet connected in parallel. You MAY have blown the tiny speaker in the Heil as well as a protection bulb. Use an ohmmeter to check continuity of the speaker driver voice coil.
Jul 06, 2011 | Dunlop Ht1 Heil Talk Box
Heil microphone gm series wiring diagram to suit kenwood ts 450
This is the pinning of the GM-series.
pin 1- Ground / shield
pin 2 - Mic (audio)
pin3/4 - PTT
On the 450 the next;
pin 1 - Mic (Audio)
pin 2 - PTT
pin 7- Ground (Audio)
pin 8- Ground (PTT)
Good luck,
Gerard
Jan 21, 2010 | Heil Sound PR-40 Professional Microphone
I need a wiring diagram for a Heil A/C packaged unit.
i need packge a/c units electrical diagram
Jul 04, 2009 | Heating & Cooling
Cooling fan inop
the cooling fan is a one speed motor. operates only with key on.
The integrated control module (ICM) and the engine computer control the fan.
on at 102 degree C (@ 230 F), off at 99 degrees C (@ 230 F).
You have 3 fusible links, 2 18 gage brown and on 20 gage dark blue providing power to the ICM. You should ahve 12 volts the pink/black wire, the black/orange wire and the yellow wire going into the ICM.
First, jumper 12 volts from the battery directly to the terminal on the motor where the dark blue wire goes. Make sure the black wire is grounded. If the fan works, check the items above.
I can sell you this Ford wiring diagram book for a 91 Mustang for $10 if you are interested.
please rate as solved if this helps you, thanks.
Apr 22, 2009 | 1991 Ford Mustang
I Am looking for heil NPA HC36 AKOL air conditioner wire diagram
You will need to contact a Heil distributor to get a wiring diagram. Or you can try a dealer but they probably won't help you fix your own unit. That would be taking money out of their own pockets.
Mar 10, 2009 | Heating & Cooling
89' Buick Troubles from Preston
need a diagram for the order the spark plug and pannle wires go.
Jul 21, 2008 | 1989 Buick Electra
514 people viewed this question
Top Heil Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Heil Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
