Question about GE WBVH6240F Front Load Washer
GE WBVH6240FWW front loader makes a lot of noise when washing. Tub looks like it is crooked. It still washes, just sounds horrible. Any ideas?
Also noted that it leaked with the last load.
    Master:
  • GE Master
  • 753 Answers
Could be the dampers are broken or loose also could be a spring has come of the top of the tub.
Posted on Feb 05, 2014
SOURCE: GE Front loader washing machine
renew your door seal
Posted on May 27, 2007
  • 5 Answers
SOURCE: GE front load washer model #WBVH6240FWW leaks when
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Posted on Sep 27, 2009
SOURCE: Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Posted on Oct 02, 2009
  • 327 Answers
SOURCE: GE Profile front loader washing machine is leaking
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Posted on Jun 14, 2010
TheMobilian
  • 8220 Answers
SOURCE: Need to remove the front
Your service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 13, 2010
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
How can i order a rubber seal for my ge front loader washer wbvh6240fww
I found the best site was Sears parts site. They usually have the schematics so you can order the right part and is you may need another.
Jul 02, 2014 | GE Energy Star WCVH6260F Front Load Washer
LG Tromm WM2277 leaking from back bottom
The last spin is the final Emptying phase. There has to be a leak somewhere in the exiting water route. All tubing and the water pump along with all clamps will need to be checked for integrity.
Poppa
http://www.cdbaby.com/cd/poppamadison
Aug 04, 2012 | LG WM2277H Front Load Washer
I have a 07 Chevy Silverado w/ 5.3L. I presently have 105k on it and have noticed that in the last 12 months, my oil consumption has increased dramatically. Following the oil life monitor since my last...
double check for leak at rear of engine where engine block mates the transmission .the housing for the rear seal is bad about leaking on these engines at 100,000 miles
Dec 25, 2010 | 2007 Chevrolet Silverado 1500 2WD
My front loader shakes.. when in the wash and spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 13, 2010 | GE WSXH208A Front Load Washer
I'm so not adoring my adora front loader right now!!!! I know about the cleaning the filter! (Thanks GE!!) My new problem is... when in the wash cycle it is making a HORRIBLE noise. Any suggestions???
try opening the door and lifting the inner drum up, if there is lift in it give it a spin with your hand if it grumbels the main bearings have worn out,, and its not a cheep job to replace them,
Feb 24, 2010 | GE WSXH208A Front Load Washer
My Ultimate Care II washer starts leaking from the bottom front of the washer as soon as it starts to fill with water.
Good day,
That's almost always a bad pump. It is located in the front middle of the machine, at the bottom.
I'm enclosing a tutorial that is not limited to changing the pump, but it will get you there.
Note: The screws for the top console are located in 3 different locations. Both bottom corners, both bottom corners but hidden by two plastic end caps, and lastly, on the back.
http://www.youtube.com/watch?v=WLPGs2UMUJc&eurl=http%3A%2F%2Fappliancejunk.com%2Fforums%2Findex.php%3Ftopic%3D67.0&feature=player_embedded#t=15
Feb 09, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
GE WBVH6240F Front Load Washer Logo
124 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
