Question about JVC Portable Kaboom Box
I have the original jvc kaboom box and the headphone jack is causing problems because the music would play loud normal then it would suddenly stop and i have to play with the head port until the music
Headphone port short causing speakers to go silent
  • 105 Answers
SOURCE: Loud, high pitched hum from speakers . . .
This is GroundNoise from the TV's Backlight.
Sorry, but unless you are a Technician, you will simply need to ignore it.
If you are a technician, you can fix this by grounding the Audio ICs to the Power Supply (details not provided)
Posted on May 18, 2009
  • 5 Answers
SOURCE: Play Ipod thru JVC CD car stereo using RCA cable?
JVC KD-S731R does not have the option of connecting an ipod. The RCA ports on the rear of the unit are a Line-Out. These RCA's only OUTPUT sound. Not an INPUT RCA that you require. The only other method of using an ipod with this stereo is to purchase an FM-Modulator to connect the ipod. Once purchased, you must connect the antenna wire coming from the vehicle to the module, then you must connect the antenna wire coming from the module to the stereo. The other wire will be connected to either a jack or a ipod specific plug depending on the type of modulator used.
Posted on Dec 11, 2009
SOURCE: No sound or input
You have the center sound on in your menu, just turn off the cneter sound option and it will all come back on
Posted on May 22, 2010
dunnbiker
  • 8546 Answers
SOURCE: I just bought jvc kaboom.
Apparently the kaboom accepts usb.
http://www.jvckaboom.us/node-493964-B0032WL2FU-JVC_Kaboom_System_for_Ipod.html
"Features: This powered woofer CD system features twin super woofers with powerful bass sound, connection for iPod, and USB host."
What do we know about your Satellite Radio?
Posted on Jan 22, 2011
Can't get headphones to work on this unit
Aux-in jack is used to play another device such as an Ipod or other sources through your Jensen player, using it as some sort of an amplifier. Look for another port on your Jensen player that says "audio out" or "Spkr" (means speakers) to plug in her headphones. If you can't find any of these ports then you might have purchased a n actual boom box, which does not have the capability to play through headphones, sorry about that.
Dec 28, 2013 | Jensen cd-472-bk am/fm cd boom box
My headphones crackle with loud music
your headphones my be damaged or "blown-out" This is common when played at high volumes. the crackling you hear is the result of the voice coil in the driver (speaker) contacting the cone. the only way to remedy this is to either replace the driver in the headphones or get better made headphones.
personally I recommend JVC RX300 because they are loud and have good sound quality and are cheap enough that the can be replaced when broken.
Jul 17, 2011 | Audio Players & Recorders
I have a Frontman Fender 25R, it has a power, the auxilliary input is working (the RCA, red and white ) sound is produce, when I plugged an electric guitar on the 1/4 input there is no sound coming...
You actually have the "B" version as the original 25R doesn't have RCA jacks. Anyway, on with your problem...
I want you to do a test: With a set of headphones plug them into the preamp output and then play your guitar... don't expect much loudness, it may be very faint and will ONLY be in one of the sides of the headphones. This tests the preamp section... have the guitar volume wide open.
IF you can hear the guitar that way, then the switch contact on the PA INPUT jack (not the preamp output) is not making contact. These jacks are really poor and the problem is not that uncommon. Fix is to open the unit and increase the spring tension on the contact or replace the jack. Never use the jack as they worsen evertime you plug something into it.
Note that the failing switch symptom MAY be broken soldering in the vicinity of the jack so look for that also. And also check the soldering of the guitar input jack as that is a common problem. Always loop your guitar cable through the handle so tripping over the cable doesn't break the jack by yanking the plug sideways... another common problem.
Mar 25, 2011 | Fender FrontmanTrade 25r Combo Guitar...
Line 6 spider 210 volume problem
The bypass switch in the headphone jack is likely broken. NEVER unplug the headphones while the amp is on.
There are certain small amps that have a possibilty of popping the power amp due to a feedback arrangement. Likewise, never use the headphone jack for ANYTHING other than headphones.
Dec 20, 2009 | Music
Speaker Problem ..
there is no official chineese version of nokia N95.
Its the problem with the firmware. Update it and everything will be fine
Jul 02, 2009 | Nokia N95 Cellular Phone
MUsic not playing correctly on iPod Touch
this problem is the same with me! i dropped my iPod, but it cracked the screen and i'm pretty sure i haven't dropped it on the jack because im very careful with it!!!
Jun 06, 2009 | Apple iPod touch
ITouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Apr 16, 2009 | Apple iPod touch
Sidekick LX headphone jack PROBLEM
yea, i broke my headphone pin inside the jack now i can't get it out what to do :)
Aug 12, 2008 | T-Mobile Sidekick
JVC Portable Kaboom Box Logo
21 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
