Question about Technics Audio Players & Recorders
Locked won t turn
Our turntable on the technics had the belt replace a few yrs. ago. It's never used and is in a closed cabinet. Now I am trying to use it, checked the belt, it's not broken but the turntable will not turn. We do have power, however?
  • Linda Torrence
    Linda Torrence Jan 03, 2014
    Okay, in 4 or 5 yrs. if not less it has been used. We had my son-in-law who works in a huge electronic firm set the mechanics on it and replace the belt. It played perfectly. He use to work for Lockeed Martin. Now only does audio for a larger firm. I wish he loved here now so he could tell us what is wrong with it. I see no way that the belt would all of a sudden age or deteriorate, it looks in perfect shape and I can move it. Like I said, it's in a closed cabinet, so it's not like dust is getting into it. I hate to get rid of it, just want to get it to working with my other components as I just came into about 50 very rare records. I appreciate you taking time to help, but their has got to be a better solution?
    Top Expert:
  • Technics Master
  • 43,095 Answers
The belt has stretched from age.
Posted on Jan 03, 2014
5 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: I need to put new turntable belt on a Technics SL-B200
The belt goes underneath the turntable platter. First you attach to the lip on the bottom of the turntable platter, then you put the platter on the turntable. You'll see some holes on the platter, after you put it on, just rotate the platter, until you see the motor shaft, then pinch the belt around the motor shaft.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Posted on Jan 11, 2009
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
Posted on May 21, 2008
djproaudio
  • 515 Answers
SOURCE: technic 1200 mk2 turntable wont spin
need to know if it powers up. Does it try to spin, do you hear it trying to spin? More than likely the on/off switch went bad. No, I am not referring to the ON/OFF knob. THere is a switch this engages when turned. The part is S601. You might also want to replace the Start/Stop switch as well. If neither work, then the issue is on the main PC board, and probably IC101, or IC201 with the problem. At this stage, you will have to have a service tech look at your unit.
Posted on Nov 02, 2007
  • 69 Answers
SOURCE: Crosley CR66 turntable not turning, belt is fine - motor?
frozen motor maybe or blown interal fusesmaybe,try manualy spinig platter to try an maybe free it up
Posted on Aug 08, 2009
AL-A1 turntable won t turn
take the platter & belt back off, then check to see if the motor spins, if it does the belts the wrong size or put on wrong, if it doesn't spin then you better get your butter & jam out, to put on your toast.
Jan 19, 2014 | JVC Audio Players & Recorders
I have a technics automatic turntable that had a belt replaced about 5 yrs. ago and now the turntable won't turn, even though we have power to it.
Remove the rubber mat and see if the belt is broke or has come off. You can see it through the access holes on the platter. It may have stretched or went bad also.
Jan 03, 2014 | Audio Players & Recorders
Technics SL B210 - New belt, but still "plays up" on 45rpm
Do on thing Oppen the Turntable and replace the 5 electrolytic capacitor ( 330mfd 16V,3.3Mfd 25V, two 2.2mfd 25V and 47mfd25v )in the circuit board. Also try to replace the 2 Vriable resistor ( 2K and 5K) in the circuit board of which one is for setting the speed of 33.33 and another for 45 rpm. If you need the service manual then just get in to the following link. You have to wait for some time until you will get a notification that Get the manual.
Ajin
Service manual
Feb 27, 2012 | Technics SL-DZ1200 Turntable
I have a problem with the turntable I just purchased...
Hi, remove the platter and check that the belt has not come off. Cheers john. Styluscity
Nov 12, 2011 | Technics SL-BD20D Turntable
I have a technics slbd20d for about 6 yrs. teh speed started to fluctuate, so i replaced the belt, with an orginal replacement from panasonic, and one from lp gear to match my turntable. but the speed is...
u mean the recor speeds and slows down? if its an older turntable there is some play in the bpms thats why most people get direct drive. my sugguestion is to look it over and tinker w things but dont break it. im sure you can find a manual online
May 05, 2011 | Technics SL-BD20D Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Oct 09, 2008 | Technics SL-1210 Turntable
Howdy Ivy:
for about $16.
Paul H.
May 03, 2008 | Technics SL-1210 Turntable
Turntable grinds to a halt.
The Technics SL-BD22 is a belt driven turntable. It is most likely possible that the belt wore off, wore down, or could have spun off. The platter should have 2 holes in it. One of them should alow you to see, and replace the belt. YOu can lift the platter off the turntable via those two holes. MAKE SURE IT IS TURNED OFF AND UNPLUGGED......
You can find a replacement @
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES-Drive_Belts/c271_272_278_398/index.html
And the part should come with instructions. Those guys are very thorough.
Keep me posted.
Nov 05, 2007 | Technics SL-BD22 Turntable
71 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
