Question about Optimus Heating & Cooling
Optimus H5300 heater won't turn on
Heater won't even power up. Have tried to reset tip over switch but nothing. Can't find a fuse to replace. Help! It's -2 outside
    Problem Solver:
  • 17 Answers
How old is it and has it had lots of continual use?
If it's old and you've used it a lot I'd suspect corroded wires. I've fixed many of these all with the same problem. The wires corrode to the point where they just fall away from where they were attached. I've seen switches get brittle and break apart and thermostats go bad.
Take the cover off a look at the ends of each wire. I just replace them when the ends don't look so good. Make sure you use the same gauge or thicker wires with high-temp insulation.
Newer heaters usually have fuses so look anywhere you haven't looked before where there is a power wire.
Posted on Jan 07, 2014
Buffalo12980
  • 625 Answers
SOURCE: Cadet heater quite working
that round metal thing is called a klixon overload. look on the side of it and an amperage range should be there. replace the unit and the element should work unless the element itself is blown. check for continuity across the element with your meter with the wires disconnected.
Posted on Nov 04, 2007
hotuna
  • 288 Answers
SOURCE: heater won't come on when temp drops...must reset limit switch every time.
The limit switch is shutting off and you are having to press the re-set button, right? The limit switch, if I am understanding you correctly, is the thermal disc type, may be ok, but what is causing it to shut off? I would first, not put total faith in the serviceman (PG&E maybe) and replace the limit switch. Its only a few bucks,and easy to do. Then if its still the same problem, look into the venting pipe. As it may not be adequate for the heater. Espically if its new. These new wall furnaces are kind of touchy. It may be larger, BTU wise, and the vent pipe may need to be enlarged. If this is a big job, and a bit too impractical, check the vent pipe, make sure its in good conditon, no leaks ect. install a cO2 detector and by-pass the limit switch.
Posted on Jan 07, 2008
SOURCE: Alarm light staying on.
I have the same problem. I removed the center panel on the back of the dish and found a fuse inside a white insulating sleeve. The fuse is open, preventing the current from reaching the heating coils. On the fuse it says 121 C. and 15 A.; I assume that it is designed to blow if the temp. of the dish exceeds 121 centigrade or the current exceeds 15 Amps. I don't see any reason to believe that either has happened so I suspect that these fuses just spontaneously fail. Now I just need to find a source for new ones. I wouldn't recommend jumping the fuse as it could lead to a fire.
Posted on Sep 05, 2008
  • 22 Answers
SOURCE: Laars lite 2 LG or LD Pool Heater- Heater won't stay on
the control module is the problem it allows the heater to come on then turns off power to the gas valve.if you are not getting enough water flow the high limit is turning the heater off then your problem is flow.
Posted on Feb 19, 2009
SOURCE: Optimus H-4438 Electric Heater
On the back of the heater, remove the element connection cover ( 3 philips screws). A white wire from terminal goes into a white sleeve and turns in to red wire. Under this sleeve is a special fuse, TCO (Thermo Cutoff) that has that has blown.SEFUSE, SF110Y, 15a
Posted on Nov 27, 2009
My optimus want come on.model # H5300 BK
Internal fuse is probably blown. Are you able to use a multimeter?
You need to disconnect from mains and check continuity through the thermostat and fuse.
Nov 03, 2014 | Heating & Cooling
I have a Pelonis oil-filled electric radiator heater that will not turn on even when plugged in to a good outlet. The switch seemed a little erratic but worked but when I bumped into it this morning i
Unplug it, then open it and inspect for a loose wiring connection. If that doesn't help, then jumper across the tip-over switch to see if the switch is bad.
Jan 25, 2014 | Pelonis Disc Furnace Heater
Heater will not turn on after a tip over
Some heaters are equipped with a safety switch that removes power if it is tipped. The switch may not have reset or it may be necessary to try turning the heater in various ways to get it to reset. There is a possibility that the tipover switch may have acted only once, then failed.
Oct 16, 2013 | Optimus Heating & Cooling
Heater will not turn on after tip over
shake it and see if the tilt switch resets. >>replace anti tilt switch
Oct 16, 2013 | Optimus H-5210 Infra-Red Heater
Heater will not turn on after tipping over
there is what is a called a tip switch some of them have to be manually reset.
If not then the tip over switch is stuck rock it back and forth or gently shake it ans see if it will go back to safe position
Alarm light comes on as soon as I turn on heater, preventing heater from coming on.
You can replace this fuse with a circuit breaker from RadioShack (part # R59-15A), and then the next time it trips you can reset it, instead of having to replace the fuse, which requires soldering.
Jun 30, 2011 | Optimus H-4436 Electric Heater
I have an Optimus radiant heater dish with the remote control. I love it, but it's broken. It will not turn on. It is fairly new. What can I do to repair it?
It may be the remote control. Have you tried operating the heater without the remote? If you haven't give it a try. This will tell you if the problem is with the remote of not. If works without using the remote, the remote may need new, fresh batteries. If that doesn't solve the problem, turn OFF the Master Switch on the heater to OFF. Unplug the heater and wait 12 to 15 minutes before plugging it back in.
Turn the Master Switch on the heater ON. And try operating it. Hopefully, that time out, gave it enough time to reset itself.
Mar 18, 2011 | Optimus H-4436 Electric Heater
Optimus H-4338 The warning light came on and now the heater will
there's no reset, but unscrew the 3 screws in the back. Cut out white sleeve that covers the red & white wires. Take the fuse out from beginning to end. Attach the white & red wires directly. The fuse is not needed. Wrap w/ electrical tape. You, me and everyone that has bought this heater had the same problem. I called customer support. This is what they told me.
Dec 09, 2009 | Optimus H-4436 Electric Heater
Optimus electric heater can be found on amazon, click here and take a look: Amazon com optimus electric heater. I hope this was helpful. Cheers
Jan 10, 2009 | Optimus H-4436 Electric Heater
Feb 22, 2008 | Heating & Cooling
Heating & Cooling Logo
426 people viewed this question
Top Optimus Heating & Cooling Experts
Mack Baxter
Trippy Tripp
Are you an Optimus Heating and Cooling Expert? Answer questions, earn points and help others
