Question about Brother MFC 210C All-In-One InkJet Printer
I keep getting the message unable to print see trouble shooting in manual
I four new ink cartages installed and it did clean and give the a test everything was ok with that then when I tried to print a doc. it gave me this message " unable to print " " see trouble shooting in the manual " I hope you can tell me what to do to correct this problem.
Thank You in Advance
John H.
  • 5 more comments
  • trouble107 Oct 26, 2007
    Att: Mix-it-up
    As to your question the answer is " 10 "
    Thank you for your reply hope to hear from you soon.
    Thank You very Much
    Att: Mix-it-up
    I also see Machine Error 50
    Hope this of some help also.
    Thank you
    Att: Mix-it-up
    Thank you
  • trouble107 Oct 27, 2007
    Att: Mix-it-up:
    Ok I have done the above and evrything on that part sames to be ok, but the paper is jamming all the time on the right side, that back cover you remove to remove a paper jam doesn't same to be right, it's very hard to get it out or in for some reason. To me this same were the problem with that paper jams.
    Thank You again Very Much
    John H.
    PS: I don't see any error message other then paper jam.
  • Anonymous Nov 04, 2007
  • jaredm Sep 30, 2008
    Error46, reset ink tank (was only 3000 something not even close to 6045'ish as suggested MFC210c
  • njwirelessin Mar 16, 2009
    my name is enid i have the same problem so i pressed menu then start the blue bottom now it gave me an error 46 what can i do.
I have the same problem with my DCP-115C.
The message is "unable to print - see trouble shooting in the manual"
The message was comming when I changed black cartrige on new one and tests print and cleans many times (accordig to print test results).
I tried to move my printer to the maintanance mode by press start mono and 4-times arrow up, but the machine is blocked.
It means when I press start mono button (blue) the printer gives 3 pips (noise signal) and nothing do even I pressed arrow up 4-times.
Please help me to solve the problem.
Posted on Mar 01, 2008
  • 832 Answers
Press menu then start mono (blue button) then fourtimes arrow up. Machine will be in maintanance mode. What error no. does the display show off?
Posted on Oct 23, 2007
  • Mix-it-up
    Mix-it-up Oct 26, 2007
    the error 50 means that the encoder strip is out of position and has to be fixed (quite simple to do). This happens sometimes when having a paperjam. Did you had one the days before?
    Error 10 is not compute! Is it something else? Some no. with letter?
    see here
    how to open the printer (you have to put the foil which runs paralell to the printhead belt in position by fixing it into the right place at the printhead. therfore you have to turn one of the 3 white gearwheels on the left once around and push the head towards them. here you can simply lift the printhead and reinsert it by watching the encoder srtip being in the right place (to test push the head left/right and watch the strip: it should be plain to the pathway. no wave at all. plz be very careful when doing so not to stain the strip nor your fingers (:-) )with ink.)
  • Mix-it-up
    Mix-it-up Oct 28, 2007
    can take a macro picture of the side where you always receive a paper jam and post it here? Plz make sure that the printer cover is open and the angle shows half a part of the printer engine, too?
If trying to Print in Word 2003 - 2002 - 2002
Click on tools > options > Print tab > Uncheck Back Ground Printing. Click on ok. Try Printing.
If you are trying to Print from Word 2007.
Click on Office button > Word options > Advanced > Locate Print options and uncheck Backgound Printing click on ok. try Printing
Posted on Oct 19, 2007
My printer keeps saying unable to clean and trouble shooting I've tried a lots of things but nothing is work what do I do
May be an obvious thing to check, but are any of the cartridges near empty? If they are, the printer will give the message above as it does need some ink to waste in order to flush the print-heads.
Mar 04, 2015 | Brother MFC 420CN All-In-One InkJet...
I took the same cartridge had it refilled put it back in the printer keeps saying troubleshooting print cartridge what do do
when u put in a refilled cartage the reset will not engage ,so it will always read out of ink, check printer, etc.reset you printer manually everytime u print is the only thing u can do or buy brand new ink.and install new ink then remove this will let u print once,u will have to do this every time try xing out of prompt several times on youre computer if u r printing through it and that will work,but if u r printing on straight printer u half to reset it every time. hope this helps.
Jan 04, 2015 | HP J4680 Office Jet All-In-One Printer
Trouble shooting and routine maintenance
46 means the ink absorber box is full, it only costs around $10.00 to replace but you need to get into service mode to reset the counter. I'm not allowed to give out that info...
Sep 15, 2009 | Brother Multi-Function Center MFC-240C...
Just got a brother mfc 5840 cn from a yard sale and plugged it in and have a unable to clean. Trouble shooting and routine maintenance chapter in the users manual. It didnt come with one?
Are you saying it has an ERROR message "unable to clean..."?
if so, it just may need new ink cartridges.
Aug 14, 2009 | Office Equipment & Supplies
Error message
try to re-instal the driver or check the cable
Mar 16, 2009 | Office Equipment & Supplies
Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Jul 11, 2008 | Brother Multi-Function Center MFC-240C...
I cant to move my DCP-115 to the maintanance mode
First button is MENU then start b/k copy then 4x arrow-up....
Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
I keep getting an error message- unable to clean....I just bought and installed new ink cartridges, and the machine is still having trouble - I cannot print at all now. There seems to be no way to clear...
The waistinktank has to be replaced. DO NOT only reset the code but change the waistinktank! Otherwise ink will flow into the machine and will cause serious damages!!!!!!!! See link how to do that:
Oct 05, 2007 | Brother MFC 420CN All-In-One InkJet...
Automatic Allignment Problem
Your balck ink printhead is clogged with buit up ink. Manually clean it with cotton buds and proper cleaning solution, right doen where cartridge sits and the contact area the ink part of cartrigde contacts. Try printing now. Did you reset ink levels too?
Aug 27, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Brother MFC 210C All-In-One InkJet Printer Logo
1,036 people viewed this question
James Cagle
James Cagle
Jim Keysor
