Question about Intimidation 8 Bit DJ Sampler
How Do I Wire Up A intimidation 8bit sampler
I WOULD LIKE TO WIRE MY SAMPLER TO MY MIXER
Ddm4000 flashing and crashing
It sounds like it got blasted with ESD, see if you can get it repaired under warrenty.
Feb 16, 2014 | Behringer DDM4000 Digital Pro DJ Mixer...
My ddm4000 starts well but then flashing lights start and loss of control occurrs
I am not familiar with your unit but it sounds like the extension cord is connected to both the lights and mixer, if so use two extension cords. I have seen a lot of horror problems with undersized extension cords.
Good Luck
I've connect my sampler to the mixer. In the RCA "send" and it won't play through my speakers. I can only hear it through the headphones. What could be the problem? I'm using Numark...
You would NOT connect an audio signal to the "send" jacks... those are OUTPUTS... In doing so you are driving signal backward enough to get to the headphones. Sends and returns are NORMALLY used on a mixer for external effects. You should either be using a LINE input jack or one for "tape input".
Sep 10, 2011 | Roland Sp404sx Portable Sampler Wdsp...
Ive just bought djm600 from ebay and once i plug in it shows no power? help me!!!!!
Was it sold as faulty?, if not complain.
Try the mains plug 1st, are the wires still attached?, is the fuse blown?.
http://stores.ebay.co.uk/methleykev
Jun 13, 2010 | Pioneer DJm600 DJ Mixer W/Sampler Black...
No sound coming from headphones using my dj mixer. however through speakers sounds fine. Im using 2 pioneer cdj 1000 mk3 and a djm 800. The sound works perfectly through speakers. how ever nothing through...
hii there, pls try to use another headphone on your mixer, if you get the same problem. It means your headphone have no problem. Problem is with the the jack of your mixture. Open your mixture and check the jack properly attached internal.
Dj Ajay
djajay@inbox.com
Nov 15, 2009 | Pioneer DJm600 DJ Mixer W/Sampler Black...
1 of my channels have snaped off my pioneer djm 700 mixer, how much will it cost 4 a new 1 to be fitted?
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do PIONEER MIXER REPAIR
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Nov 14, 2009 | Pioneer DJm600 Professional DJ Mixer...
Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Samsung HLN5065W 50" Rear Projection...
Super sampler How to get film out?
once you rewind the film line up the arrows on top of the winder then gently lift the winder to release the film canister
Jun 30, 2008 | Lomo Supersampler 35mm Point and Shoot...
Intimidation 8 Bit DJ Sampler Logo
98 people viewed this question
Top Intimidation Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Intimidation Audio Player and Recorder Expert? Answer questions, earn points and help others
