Question about Whirlpool Duet GHW9150P Front Load Washer
Broken Glass Sound
Washer finishing a load. Sound of broken glass just started. Not sure if this is the serial number but its a whirlpool duet front laid washer approx 5 years old.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 187 Answers
OK, who washing the dishes in the CLOTHES Machine?! Broken glass sound? You are sure your neighbor isn\'t playing a trick on you! I am going to guess that you have either a BAD bearing, in which it is time to look at Other Machines as an option. I mean if the clothes are getting clean and it drains all the water? Just shut the door! No I can\'t say that...Can I? Whirlpools (in my opinion) are one of the Best. The problems we are having today are these Front Load Machines are a Piece of Crap! They do not use enough water. You have to use Hi Definition 3X\'s more expensive soap..that doesn\'t Clean the garments. This sounds BAD. I had the same problem and bought a USED Whirlpool Top machine for $150 dollars from a guy who"Likes" to tinker/work on them and three years later...Going Strong! Sorry I could not help you
Posted on Mar 15, 2014
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Posted on Apr 14, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Posted on May 17, 2010
Glass separating from lid
Replace with steel lid. Parts below but first I have to get my 2 cents in!
I bought the replacement glass lid and it broke within the first week. Terrible design! They are using double sided tape to hold the glass to the hinge. There is too much spring tension to be held with tape. Way to go whirlpool engineers. I'm just a welder with 1 year of school and I figured that out? Hmmmm?
Steel lid retro fit
Whirlpool will tell you it can't be done. However I did and it works and looks perfectly.
here's the parts you need
All from a WTW8200 series washer
Part prices from Sears. I'm sure you can find them cheaper elsewhere if you look. I bought from sears to utilize the return policy while figuring out what parts to get. Thanks Sears! Give them the business if you can!!
1 pc 8572026 Steel lid $40.90
2 pcs 8563964 hinge $6.99 ea (hinge from the glass lid are different and the screw holes won't line up)
4 pcs W10119828 $3.99 ea (could probably get from the hardware store for half the cost.
Solution 2:
buy a replacement glass lid from whirlpool and send them your broken original glass lid and get a refund for the one you just bought. Repeat as needed until they figure out they need to produce a quality product.
Keep your whites...White and your colors bright America!!!
Nov 20, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool duet ht washer make loud thumping sound during spin cycle
you could have a broken shock but most of the time it's a damaged spider gear and you'll need to replace the washer because the part alone is 500 bucks.you're using to much detergent and it eats at the spider gear and it falls apart
Oct 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Main Dryer Knob Broke Off
Check the Yellow Pages for a repair shop. Make sure you have model number and serial number BEFORE you contact them.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer Glass window in front load door glass is broken.
they should replace it. sounds like problem with unit.proberly only replace door . good luck with it.
Apr 08, 2010 | Kenmore Front Load Washer
Broken plastic front door cover.
I take it you live in Perth, Scotland and not Perth Australia.
Contact whirpool direct and say that you need part number 4812 440 10817 it shows on whirlpool database as a glass door frame but it means it's the plastic around the glass ( I promise you) acording to my system ( I'm a Whirlpool engineer) you can get one direct from us for about £22.77 plus delivery or you could go to your local retailer with the part number given and see if you can get it cheaper
Feb 23, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool duet washer went out of balance during the spin cycle
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
