Question about Campbell Hausfeld 26 - Gallon Air Compressor
Blowing circuit Campbell Hausfeld 26 - Gallon Air Compressor ran fine all morning. In the afternoon it kicked the circuit. It seems like it got to hot. let it cool down a while and now it wont build up pressure and is still kickin circuit. Any help would be greatly appreciated. I have a couple of roofing jobs i need to get done. Thanks in advance. LJ
  • 585 Answers
Does it sound like it's running the usual speed? If it's at lower speed, it may have a problem in the motor, or a voltage drop condition exists. If speed is near normal, check the reeds in the compressor, or the checkvalve between the head and the tank.
Posted on May 22, 2009
  • Bruce Volkers
    Bruce Volkers May 25, 2009
    Did you get this resolved?
My compressor charges up to 60 PSI. It keeps on running but will not charge over 60PSI. I feel or see no leaks. Why?
Reed Valves in cylinder head. Pull head off and order Valve Kit through Campbell Hausfeld. Phone number etc is on internet.
Apr 27, 2010 | Campbell Hausfeld 26 - Gallon Air...
Electric compressor motor problem
Unloader valve on switch. That switch is not bleeding off cylinder head pressure,when it shuts off.
Apr 06, 2010 | Campbell Hausfeld 26 - Gallon Air...
Not building pressure, was this morning but not this afternoon
Usually a sudden loss of capacity such as this is due to a broken valve in the cylinder head of the pump, most manufactures offer a complete replacement head plate with gaskets in a kit form, not to difficult to change out.
Dec 15, 2009 | Campbell Hausfeld 26 - Gallon Air...
I have a 26 gallon campbell compressor elec. Problem is runs fine for a min. then shuts off and on every couple of min does not get to max psi
REPLACE THE PRESSURE SWITCH BUDDY THESE CAN BECOME FAULTY WHICH IS THE CASE OF THIS PROBLEM BUY THEM ON EBAY FOR CHEAP THE PRESSURE SWITCH CONTROLLES YOUR ON AND OFFF AND STOPING PRESSURE SO THAT HAS GOT TO BEE THE PROBLENM OR TRY AND TAP IT A BIT TO MAKE IT WORK
Oct 21, 2009 | Campbell Hausfeld 26 - Gallon Air...
Campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Oct 05, 2009 | Campbell Hausfeld 28 - Gallon Air...
Compressor whining and blowing air. Sounded like engine siezing. 20gal oiless compressor
hi remove compressor unit try motor if ok strip comp hope this helps merlin v12
Jun 15, 2009 | Campbell Hausfeld 26 - Gallon Air...
Compressor is getting so hot it is smoking
Make sure you are running compressor oil in it. Not motor oil.
Apr 23, 2009 | Campbell Hausfeld 26 - Gallon Air...
Could I have blown a fuse on my Campbell Hausfeld compressor
your compressor does not have a fuse, look on the side just under the plastic cover.there should be a small c/b switch, just push it in. should work.
Jan 03, 2009 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
314 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
