Question about iLive IHB23B - Ihb23b Wireless 2.1 Channel Bluetoothr System
Wont pair with a toshiba t.v
Wont pair or connect to t.v
How can I access Bluetooth for my Toshiba lap top using windows 10
Connecting Bluetooth devices to Windows 10
  1. For your computer to see the Bluetooth peripheral, you need to turn it on and set it into pairing mode. It typically involves pressing and holding the Bluetooth button until you see a flashing light that indicates the pairing is ready.
  2. Then using the Windows key + I keyboard shortcut, open the Settings app.
  3. Navigate to Devices and go to Bluetooth.
  4. Make sure the Bluetooth switch is in the On position. (You'll know it is working because you'll notice the message that reads "Your PC is searching for and can be discovered by Bluetooth devices.")
  5. Select the device you want to connect and click Pair.
May 06, 2017 | Toshiba Computers & Internet
How to get bluetooth speaker to connect already apired and is showing but wont connect
Hello, I have already met this issue: after pairing a bluetooth speaker on a first host (computer or iPad), then pairing it on a second device (as another computer for example), when I try to pair it again to its original host device, it doesn't work.
The solution consist in
1) on the host computer, in the list of the Bluetooth devices, delete the line of the bluetooth speaker and forget this bluetooth device,
2) push on the Bluetooth detect button on Bluetooth speaker,
3) scan the bluetooth devices on your computer host, and when you see the bluetooth speaker in the list, select it.
Jul 28, 2014 | Toshiba Satellite Laptop with AMD Athlon...
Toshiba tv what is a pairin coad
A Pairing Code is generated by the originating device which must then be typed into the second device in order to protect security of devices. Usually a xxxx 4 digit number is used. It appears on the first device when setting up the Bluetooth connect for the first time.
The Bluetooth is put in discovery mode & then creates a random Pair Code when it discovers another connectible device.
eg. You use Bluetooth headphones to Pair with your iPhone. The code is usually 0000 for simple devices.
If you want to Pair your iPhone with your Car's Radio/Amp then you go through the pairing routine to match the two devices.
But you don't want the guy next to you connecting his music into your radio so he is required to "Pair" first
Was This Helpful?
Then tick the box!
Jun 29, 2014 | Cell Phones
How to hookup a bose 321 to a toshiba 58l7300 tv
The Bose system does not appear to have HDMI output. The best-quality method would be to use Component (RGB) cables with analog audio. One RCA pair will be for audio and these are often RED & WHITE connectors, but don't have to be. Any RCA pair will work. Connect these to the Bose RED/WHITE jacks found in the "TV" labeling. Connect the other ends to the Toshiba's RED/WHITE jacks on the bottom row, first two jacks.
Now you need a Component cable. This has three RCA connectors at each end and are traditionally RED, GREEN, and BLUE. Again, colors do not matter as long as you connect the ends so they match. Under the "Component" labeling on the Bose, you will find the three colored jacks. Connect these to the Toshiba's same-colored jacks which are next to the RED/WHITE ones you used previously. These three connectors carry the video signals. They will transfer Hi-Def 1080i signals, not 1080p, but you wouldn't be able to tell the difference.
Switch the input on your TV to "Component".
Dec 29, 2013 | Toshiba Car Audio & Video
Toshiba pairing code
Add code to 1 and then to onother devince
May 26, 2013 | Computers & Internet
How do i connect my wireless keyboard?
Wireless keyboards need a USB or Bluetooth connection depending on witch for USB plug in the USB dongle and tap the sync button but for Bluetooth ur internal or USB Bluetooth dongle must be in pairing mode and the wireless keyboard in pairing mode as well
Jun 04, 2012 | Toshiba DX735-D3302 All-In-One Desktop
Cellnet Pico Bluetooth Headset wont connect to nokia 5800
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
Take care.
Jun 10, 2010 | Cell Phones
H700 wont connect to lg rumor
after pair successful highlight the headset and hit connect
Jan 07, 2009 | Motorola Mobility H700 Wireless Headset
Lg env2/ jabra vbt85z bluetooth pairing
You will have to go in and reconnect it. When it says allow, be sure to push yes. You may have accidently turned of the internal connection in your phone. Go to bluetooth menu in your phone, click the bluetooth that is yours, and click connect. I did that once, and this fixed my problem. I dont think you can have it paired to more than one phone at a time. It wont know which one to answer. Good luck.
Nov 08, 2008 | Nokia 1600 Cellular Phone
Headset wont connect to phone
Have you try re pairing the headset to the phone? Most of the time we forget to put the headset in "pairing" mode so therefore the phone will not recognize it. Try that and let me know.
Mar 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
iLive IHB23B - Ihb23b Wireless 2.1 Channel Bluetoothr System Logo
37 people viewed this question
Top iLive Video Cameras Experts
Are you an iLive Video Camera Expert? Answer questions, earn points and help others
