Question about Hasbro Big Hugs Elmo
Big hugs elmo needs to be reset
Our Big Hugs Elmo only says "ahem" and "that's too tight" while in play mode.
  • Devon Sooklalsingh
    Devon Sooklalsingh Jan 09, 2014
    I am having the same issue....EXACTLY the same! :(
I tried the suggestion but still not working, how do u get him to wake up if foot is pressed down?
Posted on Feb 09, 2015
  • Anonymous Dec 03, 2016
    Same here. He doesn't wake up when I turn him on, left foot pressed or not. He only talks when I press his tummy and he's still only saying those two phrases.
I had the same problem and Joshua's answer fixed it right up. Thank you!
"Turn him off, then hold down the footswitch while you turn it on. He'll say something when he wakes up. But Keep the footswitch held down until he says a second phrase (maybe 10-15 seconds). After that you can let go and he should be better."
Posted on Feb 07, 2015
Posted on Jan 10, 2015
Hi 8 hope you were able to solve the problem if not, maybe I can help. I had a similar situation and was able to solve. The on/off butoon on his back is the key including this left foot. Try playing around with both.
Lizzy
Posted on Dec 06, 2014
Same problem, anybody figure it out?
Posted on Aug 25, 2014
Big hugs elmo only will say thats too tight how do i fix this
im having the same issue and ive changed the batteries twice.
Mar 26, 2014 | Hasbro Big Hugs Elmo
Big Hugs Elmo stopped talking
This toy does take Batteries have you tried that
Jan 22, 2014 | Hasbro Big Hugs Elmo
Elmo's mouth is stuck open
working on it now, same here 8yr old stepped on his head on accident and now its broken-not dislogged. diassembled and need adheasive to repair, keep you posted!
Jan 09, 2014 | Hasbro Big Hugs Elmo
I open image mate and the laptop says that no document camera is connected. I have changed the cords and laptop still does not read the camera. The elmo will still project an image on the projector so...
I had the same problem with a TT-12 model. Dave from ELMO provided the resolution:
1. unplug the usb cable from your PC
2. on the ELMO:
a. Press MENU > PREFERENCES > USB MODE
b. ensure that APPLICATION is selected
c. exit the MENU and reconnect the USB cable to your PC
Oct 09, 2012 | Elmo Projectors ELMO TT02RX DIGITAL...
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
My Elmo TT-02RX document camera is not working properly. The blue power light does not stop flashing when I turn it on, and I am unable to use the camera or switch over to projecting what is on my...
Your Elmo TT-02rx comes with a five year manufacturers warranty. Contact Elmo at 1-800-947-ELMO and they will instruct you as to how to trouble shoot your doc camera or send it in for warranty service.
Apr 14, 2011 | Elmo Projectors ELMO TT02RX DIGITAL...
Hokey Pokey Elmo sings and moves his hand and foot but stopped shaking and won't turn around in a circle. It worked fine then stopped working we changed the batteries and it worked a short time then quit...
Hi ms_debbie13
    How to Activate
  1. This plush, shiny red Elmo is standing with his arms up above his head. One foot is lifted slightly off the floor and the other is on the floor. On that foot, there is a swivel allowing Elmo to turn, the battery door and the on/off switch. Turn Elmo on and stand him upright then squeeze his left hand to begin his song.
    Elmo really moves his right arm and leg in time with the song, and also turns in a circle. When the song is done Elmo says, "Whew.. that was fun! Elmo's pooped!"
  2. Alternative Mode
  3. The alternative mode is Elmo trying to keep up as the music keeps getting faster. If Elmo falls over he will say, "Woops!" and then he will thank you when you set him back upright.
Jan 30, 2011 | Toys
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
Need to upgrade video camera in an Elmo TRV-s8
Not sure if that can be done but give Elmo Service a call. www.elmousa.com
Feb 23, 2010 | Elmo Projectors TRV-35H Slide Projector
Hasbro Big Hugs Elmo Logo
1,018 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
